banzai510(hainz) Posted September 29, 2024 Report Share Posted September 29, 2024 Mesh in at least 15inch. 13 in stock hub cap. the 15 in in later snowflake in stock Datsun is maybe the best. If you live closer I have a set of Rota RB 7x15. Rota has a mesh OS I think but they want alot of money now but when 1st came out was like 500/600 bucks 1 Quote Link to comment
iceman510 Posted September 30, 2024 Report Share Posted September 30, 2024 (edited) 3 hours ago, banzai510(hainz) said: but the swastika wheels got to go. that wagon is to good for them. I don't know, I like those wheels. 😉 Edited September 30, 2024 by iceman510 1 Quote Link to comment
banzai510(hainz) Posted September 30, 2024 Report Share Posted September 30, 2024 One thing about a wagon is you can lower them only so much as the driveline hits the tunnel if you put 3inch blocks and a hard pull. I think 2in block in back 3 inch drop in front with 15in wheels taking up the space so it look lower than it is. 1 Quote Link to comment
Legoman27 Posted October 4, 2024 Author Report Share Posted October 4, 2024 Steering box is now refreshed new seals, input shaft bearings, and new oil should be back in the car in the near future write up here 4 Quote Link to comment
Legoman27 Posted October 18, 2024 Author Report Share Posted October 18, 2024 Car is back together again Ended up with a bit of warp and a hotspot on my brake rotors, so I got them resurfaced Made it out to a show with some people from work. Seems like there are plenty of people who have no idea what it is Cleaned up more mismatched spray paint, mostly on the rear quarter No life from the speedo so I pulled everything out expecting to find a wiped gear somewhere, but it all tested fine I think the drive cable is a little worn, and the sheathing is starting to split anyway, so I've got a new one on the way Figured I'd clean everything up while I'm in there Found some files online for a 3d printed tach project, quite impressed with the models tbh Need some paint, but it's looking good so far imo 2 Quote Link to comment
Legoman27 Posted October 19, 2024 Author Report Share Posted October 19, 2024 Tach looks pretty alright with some spray paint & paint markers 4 Quote Link to comment
Z23T Posted October 19, 2024 Report Share Posted October 19, 2024 That tach came out pretty damn nice. Can you share some info about it, like where you found the print file, and what are you using for the electronics? Quote Link to comment
Legoman27 Posted October 19, 2024 Author Report Share Posted October 19, 2024 10 minutes ago, Z23T said: Can you share some info about it, like where you found the print file, and what are you using for the electronics? Files are here on thingiverse https://www.thingiverse.com/thing:4948260 It uses a ~$20, 2" tach. Cheapest I've ever seen. We'll see how well it'll hold up The link provided on thingiverse seems to have changed, but this one looks like it's exactly the same https://a.co/d/chKRc5M 1 Quote Link to comment
KELMO Posted October 20, 2024 Report Share Posted October 20, 2024 That tach face looks like the one someone on here made, Aarondatsun maybe. Yours came out looking good. Quote Link to comment
iceman510 Posted October 21, 2024 Report Share Posted October 21, 2024 I think you are right that was Aaron. I was wondering how the tach sweep and face were calibrated to match accurately. Quote Link to comment
Legoman27 Posted October 22, 2024 Author Report Share Posted October 22, 2024 55 minutes ago, iceman510 said: I think you are right that was Aaron. I was wondering how the tach sweep and face were calibrated to match accurately. The needle has to come off to install in the new face If it ends up out of sync, it just pulls off, then you reinstall pointing to zero Quote Link to comment
iceman510 Posted October 22, 2024 Report Share Posted October 22, 2024 Sure, but the sweep has to match. For example, if 8000 RPM range on the gauge face is from 8 o'clock around to 4 o'clock, the tach has to match that same sweep exactly or the information would be meaningless. I'm just curious if he designed the face for a very specific tach. You mentioned the link changing, which I thought possibly significant. Great if it works for you, and it looks nice. Quote Link to comment
Legoman27 Posted October 22, 2024 Author Report Share Posted October 22, 2024 28 minutes ago, iceman510 said: Sure, but the sweep has to match. For example, if 8000 RPM range on the gauge face is from 8 o'clock around to 4 o'clock, the tach has to match that same sweep exactly or the information would be meaningless. I'm just curious if he designed the face for a very specific tach. You mentioned the link changing, which I thought possibly significant Ah, my misunderstanding In the description on thingiverse he says he designed the face to match the ~260 degree sweep of the linked tach Wouldn't be too hard to redo the marks for the readout if necessary 32 minutes ago, iceman510 said: Great if it works for you, and it looks nice. Thanks, I'm quite happy with it for maybe $50 all in Quote Link to comment
iceman510 Posted October 22, 2024 Report Share Posted October 22, 2024 3 hours ago, Legoman27 said: In the description on thingverse he says he designed the face to match the ~260 degree sweep of the linked tach Ahh, I missed that. Didn't look closely enough. Makes sense. Quote Link to comment
Legoman27 Posted November 14, 2024 Author Report Share Posted November 14, 2024 replaced the intake / exhaust gasket seems it was slathered in grey RTV at some point discovered I had a spare hitachi carb for some reason, so I swapped over the base plate throttle shaft seals were replaced at some point & the butterfly valves are in much better shape Haven't tried it out yet since I managed to break the coolant bypass putting it back together it was so plugged with rust that It probably wasn't doing much anyway made a new one with some hard line & a few fittings waiting on the right hoses to come in before I try it out Still working on cleaning up paint in some places slow going but it's progress and stuck on a few badges Quote Link to comment
Legoman27 Posted November 14, 2024 Author Report Share Posted November 14, 2024 Started poking around at my door cards recently 4/7 should be okay with some small patches, maybe some fiberglass the other 3 I'll need to make whole new panels the vinyl on most of them is pretty badly sun damaged so no amount of cleaning is going to do much to help the color Good news is 66-67 GM "M14 bright blue" is as close of a match as you can get. with a little heat, the vinyl stretches back in to shape as well The heat gun i've got is a small temp adjustable one for soldering, So I was able to be pretty delicate with it not sure I'd try this with a larger one so a few holes to patch along with re-gluing everything and I should have some pretty nice looking door cards Unfortunately I also walked into my door mirror and just about broke it off the car you can imagine how happy I was with myself 🙄 2 Quote Link to comment
Anonymous Waffle Posted February 2, 2025 Report Share Posted February 2, 2025 I applaud your go at repairing your door panels!! My 69 panels are in similar condition.. A few good panels, and a few bad panels.. I was thinking of making new panels entirely and going for a patterned look, but I do love the lines on a stock door card. Keeup us updated on how well the diy repair comes along Quote Link to comment
rosso Posted February 2, 2025 Report Share Posted February 2, 2025 On 11/13/2024 at 4:51 PM, Legoman27 said: Unfortunately I also walked into my door mirror and just about broke it off the car you can imagine how happy I was with myself 🙄 Sorry to see that mirror get dinked - when I park my '72 wagon (in my very small garage) for any expected longer amount of time, I take the mirror off just to make sure I don't forget to avoid hitting it. Good luck with your continued work. Quote Link to comment
Legoman27 Posted November 15, 2025 Author Report Share Posted November 15, 2025 (edited) really ought to update this more often poked at things here and there over the last year pulled apart the passenger side to clean up the drip rail and around the rear window sat for a bit like that so it got some paint pulled the windshield not as bad as I expected, but needs work will have to pull the dash to figure this out backside of the passenger A pillar decided to go ahead and pull the engine hoist wouldn't fit under the car with both wheels on, so one it is bores were pretty heavily worn on the 1.6 and one of the head bolts snapped during teardown not sure what to do with it at this point a good few bits will get robbed from it for my L20, but not much use otherwise pulled to tackle all the rust in the front end rad support may as well be made of cheese lots of crust all cut out decided I'm going to relocate the battery probably under the rear seat remade this inner panel for the bumper mount and made this panel today one of these days I'll have to get a real metal brake Edited November 15, 2025 by Legoman27 fix img link, duplicate photo 2 Quote Link to comment
Legoman27 Posted November 24, 2025 Author Report Share Posted November 24, 2025 (edited) finished one panel & started another Edited November 24, 2025 by Legoman27 rogue link 2 Quote Link to comment
Legoman27 Posted November 27, 2025 Author Report Share Posted November 27, 2025 well I guess I found myself some motivation to get this thing back together rebuilt L20b popped up an hour from me for a deal got a little moisture in it at some point but seems like it'll clean up fine I can see 050 stamped on some of the other pistons came with an offenhauser intake, headers, a matchbox dizzy and a few other spares needs an oil pump drive, otherwise looks complete Guy I got it from bought it years ago with the intent to put it in his 620, but it sat. According to him, it was used as someone's race motor in a 510 Not sure about that though, given the front sump pan that's on it given the missing oil pump drive maybe they had some fancy high-flow setup they took off before selling but who knows I just need to get in gear and finish my rad support lol 2 Quote Link to comment
datzenmike Posted November 27, 2025 Report Share Posted November 27, 2025 11 hours ago, Legoman27 said: Guy I got it from bought it years ago with the intent to put it in his 620, but it sat. According to him, it was used as someone's race motor in a 510 Hope you got it cheap. Appears to have a truck oil pan on it so he got that far, or put it in and didn't like it, took it out. An L16 oil pan from a 510 will fit right on. Any L16/18 or L20B oil pump/distributor drive spindle will work but get the oil pump from any KA powered D21 Hardbody truck. They are common and have a high volume output. The internal rotors are 13% longer... N58 head? Not really one of the production heads that came on Datsuns. Could be from an import engine. Are exhaust ports round or square? Do intake ports have small notches at the top for fuel injectors? 1 Quote Link to comment
Legoman27 Posted November 27, 2025 Author Report Share Posted November 27, 2025 Yes N58 Round intake and exhaust Exhaust has liners like my w58 No notches Quote Link to comment
datzenmike Posted November 27, 2025 Report Share Posted November 27, 2025 If it had W58 then '78-'80 engine. I have no info on N58 heads, they were not listed as used certainly not widely used, but you never know, the odd one may have got through as liners were the order of the day back in '78. I assume the header has matching round ports? Quote Link to comment
Legoman27 Posted November 27, 2025 Author Report Share Posted November 27, 2025 Square ports on the header Quote Link to comment
