POST Craigslist ads here...
 I just wish i knew a little more about those rims. They don't do that much for me.
Old Hayashis... nothing uber rare about them. Worth maybe $1000; he doesnt even have the center caps for them, which will be impossible to find. Similar to Techno Racings.
  • Replies 6.1k
http://bellingham.craigslist.org/cto/3649329503.html
1967 Datsun RL411 411 - $3900 (Bellingham)
3K33o03Hb5G85Ka5M2d2sf80492772e9b11e1.jp
3Id3F63H55Ne5I25J5d2s936e52ed79341751.jp
3Gc3Lb3H15Ic5Gd5J7d2sb00f6658279b1ac0.jp
3L53F93m85Lb5K95Hed2s2cfa665dbf5613fc.jp
3K13Gb3L95G85Ke5F9d2s03558acbaaa013c1.jp
3La3N73H85Kf5J75M7d2s963da621f7be1409.jp
3G53Ic3Jf5G95F55Hfd2scc52ab88ac301dcd.jp
3M73Lc3Fe5L95K55Jbd2s65882b1e16ab1c35.jp
I'm selling my 1967 RL411 with R16 motor. Odometer reading is 83367. Judging by the condition of the interior and cylinder walls I have a hunch that it might original miles.
It was originally an automatic. I have had it for about 4 years and have made a lot of improvements and needed routine maintenance.
The person I bought it from took the automatic transmission out and had a 4 speed manual partially installed. I bought a 5 speed tranny out of a Datsun roadster and installed it. I still have the auto if you want it. I believe it needs some repair.
Some of the things I did right away include, but not limited to: New brake pads, new slave cylinders, new ball joints, new wheel bearings, new clutch, lubed all necessary parts, replaced the head gasket that was blown. I did not re-use the head bolts. I upgraded to head studs. The motor runs very good. It burns no oil and doesn't run rich. No oil or coolant leaks. It came with only lap belts for the front. I installed retractable belts in front and put lap belts in the back. Upholstery looks all original but I think the front seats were re-done.
I did have a stereo in it but I figure the new owner can install one of his/her choosing. I did leave the 4 gauge wire from the battery to the trunk.
It does not leak water inside. It does not leak water in the trunk although it did before I owned it. The floor pans are very good as well as under the back seat. No mildew or smoker smell inside. Headliner is very good. Window are all good, I did have a couple rock chips in the windshield sealed. Dash has no cracks. Comes with collector plated too!
It does have surface rust. The rockers have a few rust holes. The fenders and quarters have some rust holes. Auto body is not a skill I possess.
The speedo quit working so it might need a new cable. I might even have one. The temp gauge quit working after the head job. I might have overtightened the sending unit. lastly, the windshield washer fluid spray doesn't work. I never took the time to look at it.
This comes with a free organ donor car. It's a PL411 so it has a 1300cc motor but there a lot of valuable parts. I also have a few bins full of good spare parts which include new bumper over riders and 2 sets of original hub caps.
Call Tony 360-398-2865 or 360-303-6217 More pictures available upon request.
Keywords: 411 RL410 PL410 SPL311 SRL311 DATSEN DATSON DOTSEN DOTSON ROADSTER FAIRLADY BLUEBIRD SSS 1961 1962 1963 1964 1965 1966 1967 1968 1969 BLUE RED GREEN BLACK SEDAN COUPE
  • it's NOT ok to contact this poster with services or other commercial interests
Posting ID: 3649329503
Posted: 2013-02-28, 8:08AM PST
Edited: 2013-02-28, 8:27AM PST
