Dirtyowlnumber4 Posted May 20 Report Share Posted May 20 Hey fellas im getting a new clutch for the datsun. Its a b210 with an A14 and a 4 speed from 1976. I bought one online when it started slipping a few years ago and it didn't work out, got one from autozone and it had the same problem. the disc didnt fit into the splines. I had to spiff the old one up and Now It's slipping again and I figure I should replace it sometime. Just wanna see if anyones got a new clutch recently that fit and has a link. Sorry is this has been covered in another thread, I couldn't find it if it has. save the boy 1 Quote Link to comment
datzenmike Posted May 20 Report Share Posted May 20 Two different suppliers and the disc didn't fit the transmission input spline??? I would assume that they are right and you are ordering something different, perhaps unknowingly. The '76 B-210 Nissan clutch disc (180mm diameter) part number is 30100-H5200. The pressure plate number is 30210-N1600 In April '76 a 5 speed was optional and it has a different disc and PP part number. Perhaps you were given it. Quote Link to comment
Stoffregen Motorsports Posted May 20 Report Share Posted May 20 Yes, the 5 speed "dogleg" box had a larger input shaft. Quote Link to comment
