22350 Posted March 9 Report Share Posted March 9 I am having the worst time getting the brakes on my 1964 L320 to work correctly New shoes, drums, wheel cyclinders, Original rebuilt master To adjust I put the car on a lift. released the parking brake cable. Tightened the adjuster until it couldn't be tightened any more, then backed off 12 clicks I am getting a "knocking" sound, which is the adjuster sliding into the end of it's floating track. Earlier I had them adjusted tighter, but that seemed to make the knock worse. Also the brakes would heat up and bind. Even at the 12 click setting, the front right brake began to overheat and pull right. I loosened it three more clicks, which remedied it, but still doesn't seem correct. I am at a loss Quote Link to comment
banzai510(hainz) Posted March 9 Report Share Posted March 9 I had this happen to my 521 the sliding adjuster the back clip lost it tension which bound to one side and thus cause my brake to heat up. I think I swaped the tension clips around then worked of thater that. I put a little anti seize the the adjuster to the back plate. then drove fow and backward hopefully to center its self. Then seem to work fine the adjuster doesnt really go bad. just clean the threads and they work but mine was the spring looking 2 prong clips Quote Link to comment
22350 Posted March 9 Author Report Share Posted March 9 2 hours ago, banzai510(hainz) said: I had this happen to my 521 the sliding adjuster the back clip lost it tension which bound to one side and thus cause my brake to heat up. I think I swaped the tension clips around then worked of thater that. I put a little anti seize the the adjuster to the back plate. then drove fow and backward hopefully to center its self. Then seem to work fine the adjuster doesnt really go bad. just clean the threads and they work but mine was the spring looking 2 prong clips I know what you mean. Everything has been replaced or cleaned and lubricated. This is so strange Quote Link to comment
banzai510(hainz) Posted March 9 Report Share Posted March 9 if you can move the brake adjuster with" just your fingers" side to side then I say its too loose Quote Link to comment
datzenmike Posted March 9 Report Share Posted March 9 Sound rather clunky, like toooo clunky. Take drum off and work the axle back and forth. Quote Link to comment
22350 Posted March 10 Author Report Share Posted March 10 So I am pulling the wheels again and I have replacement springs, so i am going to change them in the front Does the big spring go on the top of the bottom of the front wheels? Quote Link to comment
