billyd Posted January 30, 2023 Report Share Posted January 30, 2023 1984 Nissan 720 base 2 wheel drive short bed z24 engine 5 speed Why is it when I type in my truck the engine and a distributor It shows me a thousand different distributors with the four wire distributor cap on it is that the same distributor I just need to swap my cap and rotary button to it or the or they different I'm trying to find a cheap distributor and it drives me crazy when I Google something and Google won't take me where I want to go so I come to ask you guys and gals Quote Link to comment
datzenmike Posted January 30, 2023 Report Share Posted January 30, 2023 Nissan may have them at the dealer but they are about 1/2 this at NAPA for similar quality. 22162-06W03 is the '84 distributor cap number from Nissan. Maybe $15-$20? The little carbon buttons are on the underside of the cap. 22157-06W03 is the Nissan rotor part number for the '85 720. Maybe $8-$10? Use these numbers and go to NAPA or some other auto parts store. Don't go for the cheapest part. For ignition, quality should be first choice to avoid a breakdown later that will cost you way more than what you save. Quote Link to comment
banzai510(hainz) Posted January 30, 2023 Report Share Posted January 30, 2023 what does Rockauto.com show or PartsGeek Quote Link to comment
SWFL Posted February 15, 2023 Report Share Posted February 15, 2023 You can thank the Clean Air Act, the EPA and other government entities. The distributor is a big part of emissions control back then, via it's mechanical advance curve map and the vacuum advance/retard curve map. There was 3 classes of emissions regulations then: 49 state, high altitude and California. Then you had automatic and manual transmissions which usually used different distributors. Often times manufacturers did mid year changes. Lots of different #, that are usually just in the advance weights/springs and the vacuum canisters. I can't see them changing the cap and rotor though. Quote Link to comment
