mojojojo78 Posted Monday at 04:25 PM Report Share Posted Monday at 04:25 PM Over the past week my car had been smoking a lot. It was blowing smoke out of the breather on the valve cover. For the past few weeks I had noticed an excessive vibration when the engine was under load. It only happened if I was in 5th and accelerating around 4K RPM. If I accelerated slowly I didn't get the knock. So I thought there was just something loose on the engine. I couldn't find anything. On Saturday I decided I should check my valves. I had been meaning to for a while. I adjusted them to .007-.008 on intake and .009-.010 on exhaust. I had seen those numbers in a few posts so I went with them. I then did a compression test and was very disappointed and bummed out. #1 cylinder - 180 PSI #2 cylinder - 100 PSI #3 cylinder - 120 PSI #4 cylinder - 180 PSI I poured a little oil into #2 and #3 and rechecked the compression. Both cylinders shot up to around 220 PSI. So I figure I at a minimum need new rings. I still need to start taking the engine apart to see if there is any additional damage to the cylinders and pistons. I am worried that the sound I was hearing was rod knock. My plan is to try and do everything with the engine in the car for now. I don't have a hoist or a stand. I need to do all my steering linkage, so I can remove all that and probably the front cross member. Then I can drop the pan to get to the rod bolts. I just don't know where to get a good quality set of rings from. And if I need to get the cylinder cleaned out where to take my engine too. Anyone have any recommendations for the OC area in California? It would be nice and convenient if there was someplace close to Brea, CA. But I can transport the engine. Whats a good source for the rings and maybe pistons? Quote Link to comment
Stoffregen Motorsports Posted Monday at 05:01 PM Report Share Posted Monday at 05:01 PM Local engine machine shop. There has to be one near you, and they can source the parts for the motor for you. They have access to parts that aren't easily found online. For your type of rebuild, I would suggest Hastings "sprayed chrome" rings. They break in fast, but are better than standard cast rings. I'd stay away from chromoly rings as they can take forever to break in. Quote Link to comment
Stoffregen Motorsports Posted Monday at 05:04 PM Report Share Posted Monday at 05:04 PM Be sure to double check the bore size before ordering rings. If the pistons are oversize, they will have a stamping on the tops. Something like .030 or .040 or 1mm or .5mm. Quote Link to comment
Stoffregen Motorsports Posted Monday at 05:06 PM Report Share Posted Monday at 05:06 PM From the Hastings website PDF - https://www.hastingspistonrings.com/wp-content/uploads/2021/10/2022-AMERICAS-MASTER-CATALOG.pdf Quote Link to comment
mojojojo78 Posted Monday at 05:35 PM Author Report Share Posted Monday at 05:35 PM Thanks for all that information and the part numbers. Once I take the head off I can check my bore sizes and hopefully there isn't any damage done to the cylinder walls. 1 Quote Link to comment
datzenmike Posted Monday at 08:50 PM Report Share Posted Monday at 08:50 PM 220 PSI????? Just how much oil did you pour in???? Low adjacent cylinders could simply be the head gasket is blown between them. 2&3 is common as head warpage is maximum in the middle. Not saying your head is warped but check this when head is off. I think you'll simply find the gasket is blown here. Quote Link to comment
mojojojo78 Posted Monday at 10:50 PM Author Report Share Posted Monday at 10:50 PM Datzenmike, I was wondering about that. It would be nice if it was just a head gasket. I didn't pour in a lot of oil. maybe about 2 caps worth. I mostly wanted to see if the compression would go up. Quote Link to comment
datzenmike Posted Monday at 10:54 PM Report Share Posted Monday at 10:54 PM 220 seems double what it should be for bad rings. Id expect under 10% not over 100%. Well stay positive. The last bad headgasket cost me under $30 to fix. Never found the cause but it blew out to the spark plug side. Quote Link to comment
Stoffregen Motorsports Posted Monday at 11:04 PM Report Share Posted Monday at 11:04 PM Before you sand the head surface, look for dark spots where the head gasket seals around the cylinders. Quote Link to comment
