Crashtd420 Posted January 22, 2023 Report Share Posted January 22, 2023 On 1/20/2023 at 4:55 PM, JumboFett said: 40mm bearing journal Deck height 1.584” Do you know where these measurements or parts are on the diff? Trying to compare to the one in my basement.... Quote Link to comment
datzenmike Posted January 22, 2023 Report Share Posted January 22, 2023 40mm journal I bet is the inside measurement of large press in bearing on either side of the bolt in case that holds the ring gear. 40210-85000 for the bearing and it was used from Patrol to Xterra on anything using an H-190. It's also used on all R-180. 1.584" not sure, maybe the stubs the bearing presses onto? Seems a bit wide? 2 Quote Link to comment
Stoffregen Motorsports Posted January 22, 2023 Report Share Posted January 22, 2023 Deck height is probably referring to the distance from the ring gear flange to the nearest bearing seating surface. Probably. 2 Quote Link to comment
JumboFett Posted January 23, 2023 Author Report Share Posted January 23, 2023 3 hours ago, Stoffregen Motorsports said: Deck height is probably referring to the distance from the ring gear flange to the nearest bearing seating surface. Probably. The guy at DTS explained deck height as the apparent height of _?_?_ (something I can’t remember) as it sits if the carrier was resting on a table. 2 Quote Link to comment
JumboFett Posted January 23, 2023 Author Report Share Posted January 23, 2023 3 hours ago, Stoffregen Motorsports said: Deck height is probably referring to the distance from the ring gear flange to the nearest bearing seating surface. Probably. Nevermind…. Here’s a diagram from Google 2 Quote Link to comment
Stoffregen Motorsports Posted January 23, 2023 Report Share Posted January 23, 2023 Sounds like a pretty arbitrary measurement. But yeah, it makes sense. 2 Quote Link to comment
Crashtd420 Posted January 23, 2023 Report Share Posted January 23, 2023 (edited) Well the dimension requirements of the Detroit locker match my earlier 521 differential... I have submitted the question to DTS this morning to confirm it fits more than just the 2 years they state... The second news sucks, the posi unit I mentioned is no longer available and they literally took it off their website this morning..... I edited the previous post to reflect this. Edited January 23, 2023 by Crashtd420 1 Quote Link to comment
datzenmike Posted January 23, 2023 Report Share Posted January 23, 2023 It's always too good to be true. Get a Lincoln Locker and be done with it. Quote Link to comment
Crashtd420 Posted January 24, 2023 Report Share Posted January 24, 2023 Well they wouldn't say if the Detroit locker with work in anything beyond the listing.... 72-73 620.... What they did say is one sold this morning and there is only one left after that... trying to see if they will be discontinued after that or not... Jumbofett I hope you were the one who ordered, if not you might wanna jump on that last one... 2 Quote Link to comment
datzenmike Posted January 24, 2023 Report Share Posted January 24, 2023 Well my information makes a definite distinction between 620 H-190s before Sept 73 and those after, Oct being the beginning of the '74 model year. The external carrier case, the interior case that holds the crown gear, the 4.375 gear sets and the pinion bearings are different between these years. But the two large bearings are the same, the pinion shaft is the same, side gears are the same. Don't know what to say. 1 Quote Link to comment
Crashtd420 Posted January 25, 2023 Report Share Posted January 25, 2023 As a follow up they have 1 Detroit locker left and once gone they are gone... he said it's been on the shelf since 1990.... Quote Link to comment
Socalman Posted January 25, 2023 Report Share Posted January 25, 2023 12 minutes ago, Crashtd420 said: As a follow up they have 1 Detroit locker left and once gone they are gone... he said it's been on the shelf since 1990.... is this the one that fits the early H-190 ('72 521)? Quote Link to comment
Crashtd420 Posted January 25, 2023 Report Share Posted January 25, 2023 24 minutes ago, Socalman said: is this the one that fits the early H-190 ('72 521)? I wish I could say yes with some certainty... at this point its 50/50.. They say it's only for a 72-73 620, as I said before they would not confirm anything beyond that and I dont wanna waste anyone's money by saying yes.. . Mike says there are some part number differences between the years so it's up to you to be certain before purchasing.... You would have to find out how its assembled and what is needed from the open differential to be correct... 1 Quote Link to comment
Socalman Posted January 25, 2023 Report Share Posted January 25, 2023 46 minutes ago, Crashtd420 said: I wish I could say yes with some certainty... at this point its 50/50.. They say it's only for a 72-73 620, as I said before they would not confirm anything beyond that and I dont wanna waste anyone's money by saying yes.. . Mike says there are some part number differences between the years so it's up to you to be certain before purchasing.... You would have to find out how its assembled and what is needed from the open differential to be correct... Gotcha, I guess Ill find out! lol Quote Link to comment
Stoffregen Motorsports Posted January 25, 2023 Report Share Posted January 25, 2023 I wonder if there is a "case break" where some gears are thicker and the carrier has a different offset. Lots of diffs have a case break. Quote Link to comment
datzenmike Posted January 25, 2023 Report Share Posted January 25, 2023 The ring gear may be thicker width wise but to be 35/8 ratio and still 190mm the gears themselves can't be thicker. Both rings are 8 bolt and use the same fasteners. Quote Link to comment
Crashtd420 Posted January 25, 2023 Report Share Posted January 25, 2023 1 hour ago, Socalman said: Gotcha, I guess Ill find out! lol I hope jumbofett ordered his already, I'd hate for you to snipe the last one on him since he was the one who started this whole conversation... 1 Quote Link to comment
Socalman Posted January 25, 2023 Report Share Posted January 25, 2023 1 hour ago, Crashtd420 said: I hope jumbofett ordered his already, I'd hate for you to snipe the last one on him since he was the one who started this whole conversation... How long does one wait? Quote Link to comment
Crashtd420 Posted January 25, 2023 Report Share Posted January 25, 2023 1 hour ago, Socalman said: How long does one wait? No idea.... I'm hoping he sees these posts.... 1 Quote Link to comment
Stoffregen Motorsports Posted January 26, 2023 Report Share Posted January 26, 2023 (edited) I sent him an email to remind him to buy it. EDIT - he said he bought it. 😁 Edited January 26, 2023 by Stoffregen Motorsports 2 Quote Link to comment
Crashtd420 Posted January 26, 2023 Report Share Posted January 26, 2023 42 minutes ago, Stoffregen Motorsports said: I sent him an email to remind him to buy it. EDIT - he said he bought it. 😁 He must have been the one they said bought one the other morning... 2 Quote Link to comment
Crashtd420 Posted January 26, 2023 Report Share Posted January 26, 2023 19 hours ago, Socalman said: How long does one wait? Go buy it before someone else gets this idea.... Kind of sad there will be none left.... I'll have to hope to get lucky one day at the junkyard. 3 Quote Link to comment
Socalman Posted February 3, 2023 Report Share Posted February 3, 2023 (edited) Received yesterday, dropped off at the rear end place, hope it fits. Edited February 3, 2023 by Socalman 3 Quote Link to comment
datzenmike Posted February 3, 2023 Report Share Posted February 3, 2023 OOoooh that's good!!!! Quote Link to comment
Stoffregen Motorsports Posted February 5, 2023 Report Share Posted February 5, 2023 Take the tag off and keep it, or at least record the numbers and names. They may be useful in searching for more. 1 Quote Link to comment
