Mr.Disprosium Posted January 11 Report Share Posted January 11 I think I'm gonna do a 302 swap. I'm buying a 302 with a 5 speed Driveshaft and rear axle out of a 4x4 93 f150 for 500 bucks. I'm not 100% sure on it yet but what should I think about. What all will need to be done. I know v8 720s are rarely completed projects but it would be super cool to have a 720 that isn't super slow 1 Quote Link to comment
datzenmike Posted January 11 Report Share Posted January 11 At least the distributor is in the front and they are lighter than a SBC. The H-190 differential is plenty strong enough for a 302. 1 Quote Link to comment
NC85ST Posted January 11 Report Share Posted January 11 I assume that’s a divorced transfer case on that 150, otherwise you’re going to have to have a different transmission. Also if it’s a hydraulic clutch you should be ok, as far as the clutch is concerned. That 150 rear end is way to wide for a 720. Anything can be done with enough skill. Quote Link to comment
Stoffregen Motorsports Posted January 11 Report Share Posted January 11 No, the divorced t-case was dropped in the 1960s. A '93 F150 has a driver drop Borg Warner t-case. The stock Ford 5 speed is a rather long Mazda transmission and may pose some fitment problems. Luckily, the shifter is pretty far forward on the trans case, so it may come up into the tunnel at a good spot. Though you may have to cut/bend the shifter to clear the dash. Are you using the 4x4 trans and t-case? Or just the 4x4 rear axle? Either way, that's a wide axle. I'd keep the stock rear axle, or find a D44 out of an Isuzu. Quote Link to comment
Mr.Disprosium Posted January 11 Author Report Share Posted January 11 Would I be able to adapt the z24 trans to the 302 and if it was possible would it even hold up? The h-190 is the stock 720 diff?. Btw it is a 2wd 720 if that helps Quote Link to comment
bottomwatcher Posted January 11 Report Share Posted January 11 The trans would not fit or hold up. 1 Quote Link to comment
Stoffregen Motorsports Posted January 11 Report Share Posted January 11 You could adapt a Toyota W56 or R150F/R151F 5 speed trans to the 302. They are strong enough for a V8. Quote Link to comment
