ANTONI Posted December 13, 2022 Report Share Posted December 13, 2022 Hi everyone, I have a620 crew cab and I want to make it a king cab. The think is were I live this was not available and I cannot do it unless I find body parts to replace. My question is if there is somewhere I can get the part from the doors lock towards the end of the cab. If this 2pieces are available I will cut it and do swap. Any help would be great. Thanks! 1 Quote Link to comment
Bleach Posted December 13, 2022 Report Share Posted December 13, 2022 Just sell the 4-door to someone in the USA. You'll be rich! 1 Quote Link to comment
datzenmike Posted December 13, 2022 Report Share Posted December 13, 2022 You'll have to have someone slice the back half off a king cab, perhaps just forward of the door jam or B pillar, and send it to you. You graft it onto your truck. Quote Link to comment
ANTONI Posted December 13, 2022 Author Report Share Posted December 13, 2022 Yes ,that's the plan,cut half the cabin....would happily swap it with a king cab! Quote Link to comment
Crashtd420 Posted December 13, 2022 Report Share Posted December 13, 2022 Can I ask why? Quote Link to comment
620slodat Posted December 14, 2022 Report Share Posted December 14, 2022 That swap will possibly require a frame cut and weld. Datsunmike would know, or somebody more into frame dimensions than me. Or maybe a bed swap. The space between the cab and bed is what I am wondering about. Don Quote Link to comment
datzenmike Posted December 14, 2022 Report Share Posted December 14, 2022 The crew cab frame is the same long wheelbase one used on the King Cab and the single cab long box but with an even shorter box. (tray) Check your wheelbase to confirm, should be 2,785mm or 109.6" Substituting a KC for the double cab will leave a gap between it and the front of the box roughly equal to the length of the box forward of the front of the rear wheel on the green truck above. You could... 1/ cut the front bulkhead from the box, extend the box forward with sheet metal and weld the bulkhead back on. 2/ find a King Cab or a short wheelbase box, which is exactly what the green truck has. 3/ section the frame just forward of the front leaf spring mount. Have a care as the join will be very close to the cab mount which is approximately half way between the back of the cab and the door jam on the green truck. The driveshaft will need shortening this amount also and because the differential is moved closer, the driveshaft will tilt down more, possibly interfering with a cross member just forward of these cab mounts. 1 Quote Link to comment
620slodat Posted December 15, 2022 Report Share Posted December 15, 2022 9 hours ago, datzenmike said: The crew cab frame is the same long wheelbase one used on the King Cab and the single cab long box but with an even shorter box. (tray) Check your wheelbase to confirm, should be 2,785mm or 109.6" Substituting a KC for the double cab will leave a gap between it and the front of the box roughly equal to the length of the box forward of the front of the rear wheel on the green truck above. You could... 1/ cut the front bulkhead from the box, extend the box forward with sheet metal and weld the bulkhead back on. 2/ find a King Cab or a short wheelbase box, which is exactly what the green truck has. 3/ section the frame just forward of the front leaf spring mount. Have a care as the join will be very close to the cab mount which is approximately half way between the back of the cab and the door jam on the green truck. The driveshaft will need shortening this amount also and because the differential is moved closer, the driveshaft will tilt down more, possibly interfering with a cross member just forward of these cab mounts. Thanks for the pics! With those pics it is easy to see where the extra length of the frame/body is, in the bed. Don Quote Link to comment
EDM620 Posted December 15, 2022 Report Share Posted December 15, 2022 On 12/12/2022 at 10:20 PM, Bleach said: Just sell the 4-door to someone in the USA. You'll be rich! I'd happily trade my King Cab cab for your Quad cab, shipping cost would be killer though. Like Bleach said, offer that cab & doors for sale, quad cabs are the thing here. As far as the frame goes, the wheelbase should be exactly the same (only 2 frame lengths were used as far as I know - regular cab shortbox, and regular cab longbox/KC shortbox the other) requiring only the relocating of the rear 2 cab mounts and 2 forward box mounts. The shortbox sides might be available but the box floor is probably not requiring some fabrication. Between the 620 and 720 frames, they are almost 100% the same, and I believe the D21 is also the same dimensionally, with a few minor differences. 1974_Datsun_Pick-up Body & Frame Dimensions.pdf1980 720 Chassis & Frame Dimensions.pdf Quote Link to comment
datzenmike Posted December 15, 2022 Report Share Posted December 15, 2022 Pretty sure the all cab mounts are in the same position. My KC cab fit onto a long box frame (reg. cab) bolted right up. The two forward box mounts on the long bet frame had to be cut off and welded on about 9" back. Refer to the diagrams posted. The right front to the left rear cab mounts (measured diagonally) are both 2,350mm Quote Link to comment
EDM620 Posted December 15, 2022 Report Share Posted December 15, 2022 45 minutes ago, datzenmike said: The two forward box mounts on the long bet frame had to be cut off and welded on about 9" back As I did with mine. Based on that experience I suspect the quad cab would also require those mounts either moved further, or the rearmost cab mounts be modified. I know I'd love to have a quad cab, even with the KC there isn't exactly an abundance of interior room. Quote Link to comment
datzenmike Posted December 15, 2022 Report Share Posted December 15, 2022 The quad cab almost certainly also mounts to the two front box mounts. The 6 cab mounts are in the same position for all 620s. Quote Link to comment
KELMO Posted December 16, 2022 Report Share Posted December 16, 2022 Seems there is some roof line issues as well. Quote Link to comment
datzenmike Posted December 16, 2022 Report Share Posted December 16, 2022 Yeah like 4 door sedan vs. wagons. You'd think the rear doors would swap but they are not exactly the same. Quote Link to comment
KELMO Posted December 16, 2022 Report Share Posted December 16, 2022 I have actually only seen one of these Crew Cab 620's in person. While I do think they are cool the just aren't my cup of tea. I agree on the 4DR vs Wagon (510), on the 4Dr the top of the "quarter window" seems about half the size of the one on the Wagon. I may get out there today and measure the difference between the 2. Quote Link to comment
datzenmike Posted December 16, 2022 Report Share Posted December 16, 2022 610 and 710 also. Even the glass is different. Quote Link to comment
Stoffregen Motorsports Posted December 16, 2022 Report Share Posted December 16, 2022 Seems like it would be a fun project, but hardly worth the effort. Has that ever stopped anyone before? Quote Link to comment
EDM620 Posted December 16, 2022 Report Share Posted December 16, 2022 3 hours ago, Stoffregen Motorsports said: Has that ever stopped anyone before? Would we be here otherwise? 🤑 Daring to be different sometimes... Same front sheet metal but doors missing the bullet line sadly. Or once made for the Saudi market OK so I have weird tastes 🤪 1 Quote Link to comment
Stoffregen Motorsports Posted December 17, 2022 Report Share Posted December 17, 2022 620 wagon. What do they even call it? Quote Link to comment
datzenmike Posted December 17, 2022 Report Share Posted December 17, 2022 Estate car. Quote Link to comment
Stoffregen Motorsports Posted December 18, 2022 Report Share Posted December 18, 2022 Is it still even a 620? ot do they use some weird name? Like Bluebird or Fairlady. Quote Link to comment
datzenmike Posted December 18, 2022 Report Share Posted December 18, 2022 Depends where you are. In N America it's a station wagon. In Europe (or Britain at least) it's known as an estate car. I don't think they even exist. Nissan never made them. If you ask me someone grafted a 620 front end onto a 610 wagon. The rear C? pillar finisher is identical Quote Link to comment
EDM620 Posted December 18, 2022 Report Share Posted December 18, 2022 The yellow 620 "Estate" is actually a Chinese product. I have the brand name on my other laptop, if you really want to know. Because you know, the Chinese have never copied anything before... 🤣 So then does that translate to repop panels possibly being available over there? 1 Quote Link to comment
datzenmike Posted December 18, 2022 Report Share Posted December 18, 2022 They made them over 45 years ago? Or was it a conversion 'kit'? Repops used to come from Taiwan. I imagine they bought the old molds. The problem is the metal sheets were thinner and didn't form/stretch properly and they didn't fit very well. I remember some idiot trying to sell them as OEM or NO$ not in any way knowing what either term meant. It's JDM yo'. His pictures showed the date made (some time in the '80s) stenciled on the back side. Quote Link to comment
Stoffregen Motorsports Posted December 18, 2022 Report Share Posted December 18, 2022 It’s a YueLoong YLN-753W. https://japanesenostalgiccar.com/the-datsun-620-looks-pretty-good-as-a-wagon-it-turns-out/ 1 Quote Link to comment
