jchem13 Posted December 1, 2022 Report Share Posted December 1, 2022 I have a 510 that came with what I believe is a j13 engine, but the block is cracked. I was able to find a j15 would I be able use the j13 transmission with my now j15? Quote Link to comment
]2eDeYe Posted December 1, 2022 Report Share Posted December 1, 2022 I believe the J series all have the same bell pattern. Someone will be sure to verify. Quote Link to comment
datzenmike Posted December 1, 2022 Report Share Posted December 1, 2022 You should put your location in your profile. South of the border? The Mexican 510 did come with a J15 series engine. A J13 could very well have been swapped in because it fits. All the stock clutch and flywheel will fit. The J13 engine size is cast into the front left side of the block below the manifolds. Says 1300. The J15 does not. Quote Link to comment
banzai510(hainz) Posted December 1, 2022 Report Share Posted December 1, 2022 J13???? man that must be SLOW!!!!!!!!! 1 Quote Link to comment
datzenmike Posted December 1, 2022 Report Share Posted December 1, 2022 Rated at 67 hp but is this gross or net. Back then it was gross. Does 55 RWHP sound about right? Quote Link to comment
Stoffregen Motorsports Posted December 1, 2022 Report Share Posted December 1, 2022 3 hours ago, datzenmike said: Rated at 67 hp but is this gross or net. Back then it was gross. Does 55 RWHP sound about right? Yuck. Quote Link to comment
gm510 Posted January 8 Report Share Posted January 8 On 12/2/2022 at 12:46 AM, datzenmike said: You should put your location in your profile. South of the border? The Mexican 510 did come with a J15 series engine. A J13 could very well have been swapped in because it fits. All the stock clutch and flywheel will fit. The J13 engine size is cast into the front left side of the block below the manifolds. Says 1300. The J15 does not. i read somewhere ages ago that in some markets the 510 came with J13 also, not sure where though Quote Link to comment
datzenmike Posted January 8 Report Share Posted January 8 South of the border and J15 I think. Quote Link to comment
