meanmachine Posted November 15, 2022 Report Share Posted November 15, 2022 trying to find speedometer sleeve for 1984 Nissan 720 4x4 transfer case. my current one is stripped where the speedometer cable goes. I seen some pictures from Datsun Mike that looks like the one I need. I found part number 32702-g5119 but it's obsolete. Any suggestion will help Thank You Quote Link to comment
datzenmike Posted November 15, 2022 Report Share Posted November 15, 2022 32702-G5119 is not just the sleeve but an assembly that includes the 19 tooth plastic pinion also. Take yours out it may be a 17, 18 or 20 tooth and possibly they may have that one. Need to know.... 1/ Is the 10mm bolt that holds it in place at the 12 or 6 o'clock position???? 2/ How many teeth? Yellow.......... 16 Black........... 17 Blue............. 18 (pale almost white) White........... 19 Red.............. 20 You can buy just the housing from another vehicle if I know 1/ and 2/ and get the part number. Its 32707-????? if they still have them. Quote Link to comment
Crashtd420 Posted November 15, 2022 Report Share Posted November 15, 2022 Definitely pull the old one out before ordering one... There are 2 different length ones and even a slightly different one for the short tail mid 80s 720 transmission.... I have no idea what the transfer case one looks like.... Quote Link to comment
