Thomas Perkins Posted August 21, 2022 Report Share Posted August 21, 2022 39 minutes ago, NC85ST said: You did find the one nut on the lower right hand corner of the box, right? It’s between the heater and evaporator box. I forgot about it. I just went and looked at my parts truck and found it. There is styrofoam in the evaporator box that can make it difficult to wiggle off. Disconnect the lines, under the hood, going to the evaporator, it should help get it out.Yeah,that stud and nut is holding on both boxes.Got to take the 3 boxes off in order. Quote Link to comment
Joecar Posted August 21, 2022 Author Report Share Posted August 21, 2022 2 hours ago, NC85ST said: You did find the one nut on the lower right hand corner of the box, right? It’s between the heater and evaporator box. I forgot about it. I just went and looked at my parts truck and found it. There is styrofoam in the evaporator box that can make it difficult to wiggle off. Disconnect the lines, under the hood, going to the evaporator, it should help get it out. Yeah i did get that bolt removed but it was still putting up a fight. I couldent tell what the hoses are for it though Quote Link to comment
NC85ST Posted August 21, 2022 Report Share Posted August 21, 2022 There is a rubber condensate line to the right of that nut. It just pulls off. If you look under the hood, below where the ac lines connect to the evaporator you’ll see where that tube comes out. Quote Link to comment
