Datsun 620 center link flip question?
DATSUNgeo
Anybody ever use an 11/16” Champion SA80 Car Reamer to drill/ream out the idler and pitman arms when flipping the center link? I have access to one, so before I go buy an 11/16” drill bit I thought I’d ask. I will be using the TereFlex insert method for the center link flip. Thanks guys, much appreciated!
  • Replies 6
The holes are tapered.  However, they are tapered in the wrong direction if you are flipping the link(for the purposes of a KA engine swap). The reamer is 5/16" at the tip and is designed to open and existing hole to a true 11/16", if inserted or reamed to the stop guide. The TereFlex insert will produce the inside diameter taper in the correct direction to accommodate the center link I am looking for.  The outside diameter of the TereFlex insert when modified will be at 11/16".
This 11/16" hole could be achieved with a regular 11/16" drill bit but if I'm thinking correctly this reamer will produce the same outcome without the unwanted chatter and binding that a regular drill bit tend to have. Here is a picture of the reamer.
Thanks, -Geo
  • Thanks 1
