sick620 Posted August 21, 2022 Author Report Share Posted August 21, 2022 Started welding holes in the engine bay 2 Quote Link to comment
Skib Posted August 21, 2022 Report Share Posted August 21, 2022 On 8/16/2022 at 2:50 PM, yenpit said: Suggestion............leave that drip rail stainless trim ON THE CAR, work around it carefully & mask it off! They are a massive pain to remove & often get bent AND if you remove them & then lay on too much paint on the actual drip rails, they won't fit back on properly & can get beat up/dented while TRYING to get them back on! Just my 2c! As a body guy and someone whos taken quite a few off\on 510s and Zs, its not a bad idea at all lol They have a bit of trick to them, but even if you got it down they are funky. Quote Link to comment
datzenmike Posted August 21, 2022 Report Share Posted August 21, 2022 On 8/14/2022 at 7:47 PM, sick620 said: can someone ID this trans I think it’s from a later model hl510 but not sure L series F4W63 becoming an F4W63L before '74? just after the '73 PL510. Outwardly the same (26" long) visually as the earlier F4W63, but with internal changes and improvements. This style was used on the 521/520, early 620, PL510, 710 and HL510. (Used on the 610 but in 31.5" length) Has neutral switch and reverse consistent with early PL510 Later HL510 has a 4th gear switch as does the 710 and 620. The 521 has no neutral switch so by elimination probably from an early PL510. (probably) Has an interesting breather. Haven't seen that style before. Needs to be closed on top to keep crap out of transmission. This leaves... is it from a sedan or wagon??? Place in first gear and mark the input and output splines. Turn input 20 times while counting output turns. 5.91 (almost 6 turns)..... PL510 sedan (all other cars would have this gearing including wagons) 5.46 (almost 5.5 turns)..... PL510 wagon (520/521 and early 620 would also have this gearing) Quote Link to comment
yenpit Posted August 21, 2022 Report Share Posted August 21, 2022 14 hours ago, Skib said: As a body guy and someone whos taken quite a few off\on 510s and Zs, its not a bad idea at all lol They have a bit of trick to them, but even if you got it down they are funky. Had a guy come out to grab the same drip rails off of a Wagon parts car I have (yes going back on a Wagon!), he pulled them off, said they came off easy! I know the Wagon drip rail is much flatter, where as the Sedan has a consistent bow front to back, so that must be why the Sedan is harder.........?? Quote Link to comment
Skib Posted August 21, 2022 Report Share Posted August 21, 2022 1 minute ago, yenpit said: Had a guy come out to grab the same drip rails off of a Wagon parts car I have (yes going back on a Wagon!), he pulled them off, said they came off easy! I know the Wagon drip rail is much flatter, where as the Sedan has a consistent bow front to back, so that must be why the Sedan is harder.........?? Its hard to explain, but there is a trick to it. The hardest part is getting them started... but they kind of roll off the drip rail. I can pull the Z car ones off with just my hands. 2 Quote Link to comment
sick620 Posted August 29, 2022 Author Report Share Posted August 29, 2022 (edited) Went through the wiring today... There's two parts of a harness that look like they are from a 620 or 720 or something.. And I believe the 510 harness is fairly compete with fusebox ignition Etc... I can't find the part of the harness that plugs into the cluster though so I don't know if I'm missing some of it or what... Also there is no 510 heater core and fan assembly, the heater setup that was in the car I realize is out of a 620 or something as well.... So I think I'm going to run one of those cheap hot rod aftermarket heater cores... I've decided to do a Honda k24 swap in the car, I have a friend locally that has one in his 510 wagon and I will be paying him to atleast do the wiring part of the swap and possibly the custom mounts... Going to run an rx8 tranny with an adapter plate... Since I'm going to be wiring in a efi harness etc hopefully there's enough of the original harness here... I'm missing all of the front dash parts so I'm trying to decide if I should locate all the parts and put it together or just run a sheet metal dash, Since I'm going to run a swap I'll need aftermarket gauges anyways... Edited August 29, 2022 by sick620 1 Quote Link to comment
sick620 Posted August 29, 2022 Author Report Share Posted August 29, 2022 (edited) Can someone tell me what all this stuff is? I know the heater box, the shifter plate and gasket, and all the rubber plugs but not sure what the other stuff is lol.. I think I have everything to make the doors open and windows work as well as wipers.. Two wiper motors tho which one is for a 510? Edited August 29, 2022 by sick620 1 Quote Link to comment
Stoffregen Motorsports Posted August 29, 2022 Report Share Posted August 29, 2022 11 hours ago, sick620 said: I've decided to do a Honda k24 swap in the car, I have a friend locally that has one in his 510 wagon and I will be paying him to atleast do the wiring part of the swap and possibly the custom mounts... Going to run an rx8 tranny with an adapter plate... Since I'm going to be wiring in a efi harness etc hopefully there's enough of the original harness here... Nooooooooooooo!!!!!!!! Another Datsun lost to the engine swap. At least keep it Datsun/ Nissan! Or even rotary power. Hell, I'd go LS3 before I'd do a Honda swap. That just seems wrong. 1 Quote Link to comment
banzai510(hainz) Posted August 29, 2022 Report Share Posted August 29, 2022 4 hours ago, Stoffregen Motorsports said: Another Datsun lost to the engine swap. Quote Link to comment
sick620 Posted August 30, 2022 Author Report Share Posted August 30, 2022 13 hours ago, Stoffregen Motorsports said: Nooooooooooooo!!!!!!!! Another Datsun lost to the engine swap. At least keep it Datsun/ Nissan! Or even rotary power. Hell, I'd go LS3 before I'd do a Honda swap. That just seems wrong. I know I know.. but sr20s are too expensive and getting old… ca18 non turbo is about same cost as kseries also getting old and less power than the Honda motor… turbo anything is too much work and not really what I want for this car.. ka24e or de are getting harder to find and by the time I rebuild since they are all used will be same cost as Honda motor and less power… I want efi NA and around 200hp and unfortunately Honda is probably the cheapest way to obtain that… $1000 low mileage jdm motors are plentiful.. $200 rx8 6 speeds are everywhere… this kinda future proofs part availability for this car if anything ever breaks.. I used to want a Nissan only power plant in every Datsun now I just want the most driver friendly and easily accessible swap and I truly believe this is the best setup for me.. any other motor swap this would be another one of those threads where I say “I’m putting an SR in it” then I never get to it, and the car sits another 10 years .. I have connections to make the k swap actually happen so that’s the plan unfortunately.. 2 Quote Link to comment
Stoffregen Motorsports Posted August 30, 2022 Report Share Posted August 30, 2022 Ok, fine. My day job is swapping engines, and I am always on the lookout for new and interesting, or better yet, old and interesting engines for potential swaps. I have a mental list of what vehicles should get what engines. For Datsuns, I've always wanted to find one of the Prince V8s as used by Nissan in their IMSA cars from the '90s. They are out there. 1 Quote Link to comment
yenpit Posted August 30, 2022 Report Share Posted August 30, 2022 4 hours ago, Stoffregen Motorsports said: Ok, fine. My day job is swapping engines, and I am always on the lookout for new and interesting, or better yet, old and interesting engines for potential swaps. I have a mental list of what vehicles should get what engines. For Datsuns, I've always wanted to find one of the Prince V8s as used by Nissan in their IMSA cars from the '90s. They are out there. We talked about the late Nissan V8 (Armada & trucks) in a 280Z, but we ended up with an 80k mile LS1 out of a Vette. Now I just gotta find the right 280Z! 1 Quote Link to comment
Stoffregen Motorsports Posted August 31, 2022 Report Share Posted August 31, 2022 The LS is a perfect engine for a Z car. Don't know how much an L6 weighs, but a fully dressed aluminum block LS3 comes in at around 470 lbs. 1 Quote Link to comment
datzenmike Posted August 31, 2022 Report Share Posted August 31, 2022 L20B is 280 pounds so 50% more engine (two more cylinders) is 420? Give or take. Skib might know. 1 Quote Link to comment
Skib Posted August 31, 2022 Report Share Posted August 31, 2022 26 minutes ago, datzenmike said: L20B is 280 pounds so 50% more engine (two more cylinders) is 420? Give or take. Skib might know. With all stock manifolds, accessories, ect An L24 is ~425lbs and on the other end an L28et is ~475lbs, an L28e is prob about ~450lbs 1 Quote Link to comment
Stoffregen Motorsports Posted August 31, 2022 Report Share Posted August 31, 2022 I bought a crane scale a couple years ago and geeked out on it for a while. Weighed everything I could see sitting around the shop. Big block Chevvies are HEAVY!!! 1 Quote Link to comment
banzai510(hainz) Posted August 31, 2022 Report Share Posted August 31, 2022 13 minutes ago, Stoffregen Motorsports said: Big block Chevvies are HEAVY!!! FJ40 motor heavy 1 Quote Link to comment
Satisaii Posted September 1, 2022 Report Share Posted September 1, 2022 Thread drift... First swap was a 350 into a 78 280ZX with a kit from Jags That Run. Pre internet days, no idea of how I found them. Second was a 1960's 425 Rocket Olds into a slammed 1979 Jeep CJ-7. That was a rocket. Latest was a K24Z3 into a Miata. Love the K24 swaps. If you blow it up, just go grab another one. It is the modern Chevy 350 to an older hot rodder like me. 2 Quote Link to comment
five1oh Posted September 1, 2022 Report Share Posted September 1, 2022 (edited) On 8/16/2022 at 2:50 PM, yenpit said: Suggestion............leave that drip rail stainless trim ON THE CAR, work around it carefully & mask it off! They are a massive pain to remove & often get bent AND if you remove them & then lay on too much paint on the actual drip rails, they won't fit back on properly & can get beat up/dented while TRYING to get them back on! Just my 2c! I agree with this statement 100 percent!!!!!!!!!!!!!!!!!!!!! One of the main things I kicked myself about on my green build. It was the first time I removed and the last time.... NEVER AGAIN!!!!!!!!!!!!! 510s look so much better with the gutter trim. I mean just look how stupid my car looks without it... IMG_2719 by five1oh2010, on Flickr IMG_2713 by five1oh2010, on Flickr Edited September 1, 2022 by five1oh 1 Quote Link to comment
Stoffregen Motorsports Posted September 1, 2022 Report Share Posted September 1, 2022 Yeah, your car looks like shit. 1 2 Quote Link to comment
Stoffregen Motorsports Posted September 1, 2022 Report Share Posted September 1, 2022 11 hours ago, Satisaii said: Thread drift... First swap was a 350 into a 78 280ZX with a kit from Jags That Run. Pre internet days, no idea of how I found them. Second was a 1960's 425 Rocket Olds into a slammed 1979 Jeep CJ-7. That was a rocket. Latest was a K24Z3 into a Miata. Love the K24 swaps. If you blow it up, just go grab another one. It is the modern Chevy 350 to an older hot rodder like me. JTR used to advertise in magazines. I remember seeing the ads. I still buy stuff from them these days. I've only ever seen on slammed CJ, and that was an all chrome flattie with wire wheels in, you guessed it, Tijuana. 1 Quote Link to comment
yenpit Posted September 1, 2022 Report Share Posted September 1, 2022 59 minutes ago, five1oh said: I agree with this statement 100 percent!!!!!!!!!!!!!!!!!!!!! One of the main things I kicked myself about on my green build. It was the first time I removed and the last time.... NEVER AGAIN!!!!!!!!!!!!! 510s look so much better with the gutter trim. I mean just look how stupid my car looks without it... IMG_2719 by five1oh2010, on Flickr IMG_2713 by five1oh2010, on Flickr Ha, I see NOTHING stupid about THAT build!!! 😎 Quote Link to comment
yenpit Posted September 1, 2022 Report Share Posted September 1, 2022 21 minutes ago, Stoffregen Motorsports said: JTR used to advertise in magazines. I remember seeing the ads. I still buy stuff from them these days. I've only ever seen on slammed CJ, and that was an all chrome flattie with wire wheels in, you guessed it, Tijuana. John is still around?? If you talk to him, tell him TJ from Engel Imports says hello! (that was in the 1990's) His rep was Vicki, but when she was busy or out, he & I talked! I remember him advertising in Hemmings! Quote Link to comment
Stoffregen Motorsports Posted September 1, 2022 Report Share Posted September 1, 2022 1 hour ago, yenpit said: John is still around?? If you talk to him, tell him TJ from Engel Imports says hello! (that was in the 1990's) His rep was Vicki, but when she was busy or out, he & I talked! I remember him advertising in Hemmings! The business is now run by Greg. His brother, who I believe was John, passed away a couple years ago. From there, it was hit and miss, but they've got things figured out now. 1 Quote Link to comment
Stoffregen Motorsports Posted September 1, 2022 Report Share Posted September 1, 2022 Yeah, sorry @sick620 for the massive thread drift. Enough about me, let's talk about you. Or your rusty 2 door. 1 Quote Link to comment
