datzenmike Posted July 29, 2022 Report Share Posted July 29, 2022 '83 and on 720s had the vented rotors/calipers. '78-'79 620 and '80-'82 720 calipers/rotors were solid and basically the same. Later '83 and on 720 can be retrofitted to the disc brake 620 and the early 720 with some swapping of parts. Even the D21 Hardbody rotors and calipers will fit. VG powered 2wd D21s have even more braking. wayno is proof you can't have too much braking. 1 Quote Link to comment
Finspop Posted July 29, 2022 Report Share Posted July 29, 2022 1 hour ago, datzenmike said: '83 and on 720s had the vented rotors/calipers. '78-'79 620 and '80-'82 720 calipers/rotors were solid and basically the same. Later '83 and on 720 can be retrofitted to the disc brake 620 and the early 720 with some swapping of parts. Even the D21 Hardbody rotors and calipers will fit. VG powered 2wd D21s have even more braking. wayno is proof you can't have too much braking. Thank you @datzenmike. To clarify, are you saying that the D21 rotors and calipers will fit my '82? Or only later '83 and on? Quote Link to comment
datzenmike Posted July 29, 2022 Report Share Posted July 29, 2022 They should fit but it's a matter of collecting all the parts besides the rotor and caliper. I think the spindle and hub and perhaps some of the steering tie rod ends? are also needed. Quote Link to comment
SLO720 Posted August 1, 2022 Author Report Share Posted August 1, 2022 (edited) @Finspopis your truck 2wd or 4x4? The 2wd 80-82 trucks can be bolt on upgraded to later equipment, while early 4x4 are stuck with what they came with. The 83-86 2wd trucks have quite a bit of swappability as far as brake configurations and that's why I did mine. Plus no more hunting for parts. Beebani even used to make a kit to run 300zx 4 pot calipers on the later 2wd 720 trucks and non ball joint front 520/620 trucks I believe Patrick smith upgraded his 81-82 4x4 to 4 pot Toyota calipers but that's about the only swap I can think of for them. Edited August 1, 2022 by SLO720 1 Quote Link to comment
Finspop Posted August 5, 2022 Report Share Posted August 5, 2022 On 8/1/2022 at 10:47 AM, SLO720 said: @Finspopis your truck 2wd or 4x4? The 2wd 80-82 trucks can be bolt on upgraded to later equipment, while early 4x4 are stuck with what they came with. The 83-86 2wd trucks have quite a bit of swappability as far as brake configurations and that's why I did mine. Plus no more hunting for parts. Beebani even used to make a kit to run 300zx 4 pot calipers on the later 2wd 720 trucks and non ball joint front 520/620 trucks I believe Patrick smith upgraded his 81-82 4x4 to 4 pot Toyota calipers but that's about the only swap I can think of for them. It's 4x4. Looks like maybe I'm on the hunt for 'yota calipers. Quote Link to comment
Stoffregen Motorsports Posted August 5, 2022 Report Share Posted August 5, 2022 I just got rid of 20 pairs... Rock auto has them in spades. Quote Link to comment
SLO720 Posted August 5, 2022 Author Report Share Posted August 5, 2022 @Finspop This information used to be hosted on a 720 specific web forum that shutdown 1-2 years ago. Quote Link to comment
datzenmike Posted August 6, 2022 Report Share Posted August 6, 2022 8 hours ago, Finspop said: It's 4x4. Looks like maybe I'm on the hunt for 'yota calipers. No one has said that they bolt on or line up with the rotor. Do some homework. 1 Quote Link to comment
Stoffregen Motorsports Posted August 6, 2022 Report Share Posted August 6, 2022 1 hour ago, datzenmike said: No one has said that they bolt on or line up with the rotor. Do some homework. Buy one and do the homework. Nothing beats firsthand knowledge. Quote Link to comment
Finspop Posted August 6, 2022 Report Share Posted August 6, 2022 14 hours ago, SLO720 said: @Finspop This information used to be hosted on a 720 specific web forum that shutdown 1-2 years ago. That is super helpful, thank you. 1 Quote Link to comment
