Pertronix info please
1lo620
So I feel I fried my Pertronix ignition. Not sure how it happened. So I have decided to get a new Ignition and Pertronix coil. So I can by pass the ballist resistor.
Can anyone tell me what coil I should get to run with Pertronix 1741.. And how to wire it up correct. I added a picture to show how it is hooked up now.
This set up was working before I swapped out engines just recently. I had the truck running then it just shut off. Now no spark. Need help. Thanks
  • Replies 5
Check for loose wire. Does it fire up while starting but quit when the key is released?
Pertronix use the stock coil and a ballast resistor. It only replaces the points nothing more. No need to replace the coil but if you get rid of the ballast you should get a coil with the same resistance as the old coil + ballast. If you use a coil with lower resistance the increased current will blow the Pertronix up sooner.
Coil resistance about 1.5 ohms + ballast resistance about 1.5 ohms = about 3 ohms.
Coil without external ballast about 3 ohms.
If you are replacing your Pertronix Ignitor I get the Ignitor II. It is far superior to the first generation. My first Datsun I had back in 97 I put an Ignitor I in it. It lasted less than a year then failed. Every car since then I have used the Ignitor II and have never had a failure.
Ignitor II part number would be 91741
With the Ignitor II they recommend removal of the ballast resistor. It is designed to take the full 12V.
https://pertronixbrands.com/products/pertronix-91741-ignitor-ii-adaptive-dwell-control-hitachi-4-cyl-datsun?variant=31797069086756
Check out the installation instructions.
Then the coil will have to handle twice the current if the ballast is removed*. It's going to get hot! In that case get an EI coil designed for 12v from a '79 620/S10 200sx/A10 or the '80 720. These all had matchbox EI distributors and matching coils. A coil from any Z series engine will also work.
*Says in the instructions: Pair with a Flame Thrower Canister Coil for optimal performance
