Mixture solenoid click, key off completely
Yeah. What the title said. Rebuilt a carb, got it on, and it runs but I need some adjustments as I figured. Idle high (maybe vacuum, definitely NOT the fast idle cam), fuel inlet leaks a very small amount, fuel level a tad low. Had a weber previously and never had a properly functioning Hitachi.
What's causing the key to be off, out of the ignition, and rapid clicking still coming from the mixture solenoid??
  • Replies 9
Just now, A guy named Rick said:
For sure is the carburetor mixture solenoid. Oddly, I shut the door or even hit the truck hard enough it'll stop. Can hit it and it will start again. Weird. I pull every fuse out, still did it. Haven't checked relays yet. Do I have a loose connection in my ignition switch? This could be the source of my parasitic draw.
Hey Mike so I did that and same thing. But when I actually hit the Ignition switch itself it doesn't happen.. So there are 2 relays next to the battery, and the one that's closest to the headlights if I barely touch it the clicking stops. The clicking was coming from the carburetor, not the relay. But the relay stopped it. So I unplugged it and I noticed that it rattles especially when you shake it. Like something metal is rattling around inside against plastic. So I think I have a busted relay.
The relay I have is brown, possibly was blue and had been switched. It says COIL on 2 of the prongs and the other 4 look like for ON.
Edited by A guy named Rick
Probably the right one. 20 amp is plenty.  2 of those 4 other wires are connected when the relay is off the other 2 are un connected. When the relay coil is powered and the relay is on, the first pair and now open and the other two are connected. It's NC normal closed and NO normally open.
