T3fishing Posted May 11, 2022 Report Share Posted May 11, 2022 I have a 1984 Nissan 720 single cab. I finally have it to where it idles perfect and runs great through 1st and 2nd gear. When I go to 3rd 4th or 5th gear my truck starts to skip really bad under load and I don’t know what the issue could be! Any suggestions? Quote Link to comment
datzenmike Posted May 11, 2022 Report Share Posted May 11, 2022 Replace the fuel filter. It's cheap and if this does not help it was probably due anyway. It could be partly plugged and by the time you get to 3rd the carb has used up all the fuel faster than the pump can supply it. Quote Link to comment
Stinky Posted May 21, 2022 Report Share Posted May 21, 2022 HOw old are your sparkplugs, wires, distributor cap, and rotor? Watch your motor in the dark....do you see arcing around the wires? Quote Link to comment
datzenmike Posted May 21, 2022 Report Share Posted May 21, 2022 Hasn't been back since May 11th. I wonder if he fixed it. Quote Link to comment
