Torque specs for 2.4L
Joecar
  • Replies 16
I skip the loosening and go 20, 30 and 60 in sequence. I think it's far more important to re-torque them all once a year on the Z24 engine. With the engine dead cold loosen one bolt and right away torque to 60 ft. lbs. Then go to the next bolt. With this method you only have one bot loose at a time and can do them in any order you like.
For some reason the Z24 tends to blow the gasket every 100k. The constant heating and cooling cycles seems to somehow relax the grip on the gasket. Doesn't seem to bother the earlier Z22. So either the head bolts changed (doubtful) or something to do with the block. This re-torque refreshes the clamping pressure on the head gasket.
Yes. Clean the bolts and the threaded holes first. If you have a spare metric bolt laying around, cut three grooves in it with a cutoff wheel on a grinder. This makes it act sort of like a tap and is good at getting the soot out of the threaded holes. Run it in and out with a battery powered impact or drill.
I use a tiny smear of anti-seize on the threads and torque to 57 lbs, with a good torque wrench.
1 hour ago, Joecar said:
  so would i just torque them to 60lbs-ft?
Do in this sequence to 20 ft. lbs. lbs.
R...A...D
7.........8
3........4
1.........2
5........6
9.......10
Continue torquing in the same sequence to 40 ft lbs. You can skip this if you want.
Finally torque in same sequence to 60 ft. lbs.
Or you can also do it this way below.
7 hours ago, WestPac720 said:
Hope this helps. Straight from my 1986 FSM.F794C585-6C3E-4737-9563-91419E8EC283.thumb.jpeg.25d5478af0de783c7c7d2e173c452c3d.jpeg
My bolts are a little rusty and i dont have anything to clean them with.
Also i just noticed that ny engine black has these metal cylinders where water passes the head what are those and do i need more cause i only have 2 on it
On 5/9/2022 at 3:38 PM, datzenmike said:
Absolutely replace a head gasket. It crushes in order to seal properly. You only get to do this once.
Yes front and rear, left (driver's) side head bolts. You can plainly see the holes in block and head are larger to accept them. Not only to align the cam and crankshaft center lines but also that the cylinder 'fire rings' on the gasket are not off center and exposed to the heat of combustion.
Ok thanks. One step closer to the first start up in 6 years
