nissan720 Posted April 12, 2022 Report Share Posted April 12, 2022 (edited) is there anyway to test the ignition control on a 1979 datsun 620 . How can i tell if it is defective.Truck has fire but wont start.Turns over strong.Timingwas good. drove it last Wednesday.Went to drive it Saturday and it would not start.Only made a ckicking sound ,so I had to put a starter on it.I did find that the ignition fuse was blown ,so Ireplaced ie and it still won't start.Any help is greatly appreciated. Thanks in advance. Mine has the matchbox dizzy that why the topic.I forgot to mention .I pulled the plugs and there was gas on the number 2 and 3 plug Edited April 12, 2022 by nissan720 add content Quote Link to comment
datzenmike Posted April 12, 2022 Report Share Posted April 12, 2022 Pull a plug wire, stick a plug in the end and lay it on the valve cover or something that's grounded. Have someone turn the engine with the starter..... got spark? or not??? YES..... nothing further required NO...... Do the same with the coil wire. Got spark? YES.... problem is probably the rotor or distributor cap. NO..... check for power on the coil positive terminal. YES..... there is power at coil. Briefly ground the coil negative terminal and release. Got spark???? NO....... power, find out why YES..... there is now a spark, problem with the EI module. Check that distributor is well grounded. NO...... spark, coil is bad 1 Quote Link to comment
nissan720 Posted April 14, 2022 Author Report Share Posted April 14, 2022 thanks Datzenmike that fixed it. Changed the EI module. had one of those aftermarket ones up there .Found one off of a 1981 datsun 210 about 2.5 hours from my house. And now it works good!! 1 Quote Link to comment
