None_zero Posted April 11, 2022 Report Share Posted April 11, 2022 Anyone know the torque specs for the upper control arm bushings on the 720 with a z20 engine? The other torque specs for the various bushings behind the front wheels would be a bonus.. Quote Link to comment
datzenmike Posted April 11, 2022 Report Share Posted April 11, 2022 Link is control arm Upper link ball joint to knuckle spindle 58-72 ft. lbs Upper ball joint mounting nuts 15-18 ft. lbs Upper link spindle to upper link nuts are 56-76 ft lbs. Upper link spindle bolts to the frame are 80-108 ft lbs. Lower link ball joint to knuckle spindle 87-123 ft. lbs Lower ball joint mounting nuts 28-38 ft. lbs Lower link to frame 80-108 ft lbs. Lower link to tension rod bolts 28-38 ft. lbs Tension rod to frame nut 87-116 ft lbs Stabilizer (sway bar) to frame and lower link, all 12-16 ft. lbs Shock absorber Upper nut 12-16 ft lbs Lower bolt 43-58 ft. lbs For '84 2wd 1 Quote Link to comment
