Dirtyowlnumber4 Posted April 9, 2022 Report Share Posted April 9, 2022 (edited) My darn brakes stopped working. looks like i might have a leak inside the RR drum. anyone know if this part is rebuildable? or what its called so i could look for another? This is a 76 B210 by the way. Second question; I've been looking for new brake shoes and haven' t found any that work yet. I've ordered a few and they aren't drilled in the right places, and they are shorter so they wouldn't work even if i modified them a bit. Anyone know a good place to start looking for these? old shoe new shoe Edited April 9, 2022 by Dirtyowlnumber4 Quote Link to comment
Ooph! Posted April 9, 2022 Report Share Posted April 9, 2022 It is called a wheel cylinder. The brake shoes could be different from a front disc brake or front drum car or just wrong. Rockauto has images of the units installed not what you are holding, and show they have both in stock. Quote Link to comment
datzenmike Posted April 9, 2022 Report Share Posted April 9, 2022 If leaking, where's the wetness????? Possibly leaking somewhere else. Maybe master reservoir just needs to be topped up and the brakes bled??? The shoe material more to one side is a leading/trailing type shoe. They have to go on in a specific position depending on direction of rotation. The new ones can go on any way that will fit. Those old shoes are nowhere near wore out. Quote Link to comment
banzai510(hainz) Posted April 9, 2022 Report Share Posted April 9, 2022 doesnt look like wheel cylinder is bad. My 92toyota the dual brake cylinder the rear brake wasnt working. it seem to go far down the pedal. Didnt seem right. I bught a new master and now works fine. seems the rear portion of the master when pushed it just went passed the seals. But never leaked. I woudl bleed the rear just to make sure fluid come out.Later Datsun might have a valve to equelize porportion valve or soemthing Quote Link to comment
