510 Windshield wiper parts
edekalil
  • datzenmike changed the title to 510 Wind shield wiper parts
  • Replies 4
  • datzenmike changed the title to 510 Windshield wiper parts
If the wheelboxes still pivot, you can rebuild.............most seize up, some can be freed up, but many are locked solid!  I say this cuz I have likely sold 10+ of these assemblies, do NOT have any more good ones!  All 1969-1973 2dr 4dr & Wagon are the same.
You can press/drill out the broken studs & use a thru bolt or tap threads & use a slightly larger bolt/screw.
It's very tedious work but the pivots come apart, can be cleaned and then lubed with lithium grease. Same with the plastic ball and sockets. I did this on my 620 and they were maybe 30% faster after. Yes those damned studs are easy to snap off.
Thank you all for the help and info I will try to work on them but if anyone has a set I'm in for one, and they are frozen up. And thank you Mike for straightening out the title.
Edited by edekalil
