RevinD Posted March 16, 2022 Report Share Posted March 16, 2022 Hey guys, I had gotten a 720 4x4 kc for free from a buddy and was wondering on what to do. It currently has a z24 engine in it that needs some work. It has been sitting for about 10 years on a farm. Do I stick to reviving the z24 or should I swap something like a ka into it? I’m about an hour and a half away from it but I’ll try to get some pictures. From what I remember it was in rougher shape with the carb off and a new one sitting in his garage. Quote Link to comment
Madkaw Posted March 16, 2022 Report Share Posted March 16, 2022 Motor swaps are difficult in 4x4’s because of oil pan conflicts with front diff . Lots of info here on that . The NapZ is a good motor but has its faults to . Quote Link to comment
DuallyDatsun Posted March 16, 2022 Report Share Posted March 16, 2022 If you can just get the NapZ24 working. (I recommend just getting a new weber carb for it) That would be your best option. Lots of people try 4x4 swaps and never finish because of fitment issues. Plus, the NapZ engine will move a KC around plenty enough to not be an issue. If you're worried about the engine sitting with the carb off, just pour a couple tablespoons of marvel mystery oil into the cylinders and let it sit for a week. Then do your regular maintenance like new plugs, wires, oil change, etc... throw on a weber carb, and I'd be shocked if it doesn't fire right up. Quote Link to comment
ShutterMeShort Posted March 16, 2022 Report Share Posted March 16, 2022 As previously stated, the 4x4 models are notoriously hard to swap. I do believe if you find a 4x4 Frontier with a KA, it is the easiest. There are several threads about KA swaps in here - peak around a bit! Quote Link to comment
