Frontier KA swap vs 240sx KA swap????
Bryant
  • Replies 7
Only have some info on the D21 Hardbody swap. They used a shorter 5 speed and the engine intake was much different with the EFI wiring combined into the main harness. The 240sx EFI wiring was separate and easier to work with and remove. The Hardbody engine was a lot lighter and didn't have the crankshaft girdle. It was also a rear, or more rear, oil sump pick up like the 521 where the car was a front sump. I would imagine the truck KAs would be more plentiful and cheaper.
Absolutely. The 240sx uses a smaller diameter pressure plate so if keeping it use the matching 240sx release bearing collar. Collars and pressure plates should always be kept together when swapping transmissions.
