1986 Steering rebuild
geraba
  • Replies 6
I just ordered tie rod ends, a pitman arm, and a idler off of rockauto.com. I asked my local napa if they could get me any of those parts... NOPE. The center link is not available to my knowledge however, if you replace all the other parts you should be fine as there are no ball joins in the center link, they only seat into it.
Thanks for all the Info, I ordered tie rod ends from Parts Geek, They showed they were in stock but 3 of them were backordered and they refunded me, They did have radius arm bushings and a new pitman arm, Also ordered Sway bar links and Idler bushings.
I found that the torsion bars are set way too high stiff. Does anyone happen to know stock front settings?
