need some help with wheels
CEAZERKHAN
Just gonna get to the point, will 13x7 wheels fit front to back on a 1978 b210gx? i cannot find a straight answer, nor anything truely helpful. Not trying to swap to 280zx front struts or bang up the body, fine with a bit of fender rolling, but just wanting to buy wheels and get em on. hope this makes sense.
these are the wheels im looking at, simple gloss black steelie look.
  • Replies 9
Backspacing or off set, is also an important measurement.  13 X 7 is not the complete story.
/production/contentful_rt_wheel-offset-vs-wheel-backspacing/r/390x293/s/85/2f35391508f6995aa17e5d8b5878bc08adfb0919.jpgWhat Is the Difference Between Wheel Backspacing & Wheel Offset -  Autoanything
Take a rim, turn it face down, put something flat across the rim edge and measure down to the hub mounting surface.  For example a zero off set rim will measure 1/2 of the rim width.  Your new rims should match the off set you now have so the wider rim will have room. The new rims may not match and stick out and rub the fenders, too far in and rub on tight turns.
  • Thanks 1
hours later i now somewhat understand a bit more.   from what i read 15x7 with 3in. backspacing and -25mm offset will fit the rear nicely. Then for the front 15x7 with 4in. backspacing and 0mm offset will fit perfect. Not surprised if i am wrong it is almost 1am at the time of writing this. Im hoping someone might be able to confirm if anything i said there even makes sense and if it will even fit.  more info i plan on running 175/60 to 175/70. not sure yet maybe something in between. (same front to back)
Edited by CEAZERKHAN
Grammatical errors
Try again using this handy calculator... http://www.gtsparkplugs.com/Offset-to-Backspace.html
Can't check your work without knowing what you have on there now.
It's assumed that your tire and rim is positioned in the middle of the fender well with equal room on either side? Room for a wider rim to expand into? Will a wider front rim clear the strut tube? or will you perhaps need to add some negative off set to move the rim outwards and away from them?
Another factor to remember is stated rim width is not actual wheel width.  The actual outside flange to outside flange measurement must be considered, as it will be greater than the 7" stated size.  Maybe as much as 1" total (typical for aluminum wheels, steel may be slightly less).
4 hours ago, thisismatt said:
You went from 13's to 15's...
Which is only the rim diameter and does not affect width or diameter. To keep the same overall tire diameter on a 15" just select tires that are 2" shorter to keep present performance and speedometer accuracy.
For example
A 175/70R13 is 6.7" wide and 22.89" diameter.
A 175/55R15 is 6.8" wide and 22.58" diameter
For example
It makes a difference.  An X" wide wheel combination may rub at 13" but not at 15", or vice versa depending on strut angle & spring perch location.  Either way it's hard to say over the internets
Hate to rain on the party, but if in doubt, buy one wheel and tire/ mount it up and see if it fits. Worst case, you're out a couple hundred bucks.
There are wheel mock up tools that you can use with or without a tire, but they are quite expensive - https://www.summitracing.com/search/part-type/wheel-and-tire-simulator-tools
  • Thanks 1
