Connections Behind Speedo
Neatus
Evening Ratsun!
I am getting all the electrical sorted on my 73 620.
After refurbishing the light switch I noticed these two connections coming off the back of the speedo...a bullet style and a spade style.  I have one bullet style wire connection in the harness that isn't plugged into anything but according to my wiring diagram that wire (blue and white) goes to the clock which I don't have.
Any idea what plugs into these if anything?
  • Replies 1
The unused lug looks to be on the same trace as the one connected to the yellow wire and would serve no purpose. The yellow wire comes from a 'speed switch' in the speedometer. Look at your speedometer and you'll see that it only goes just below 10MPH and does not have a 0MPH. There is a switch inside. The yellow wire goes to a small amplifier box (shown) with two wires and this turns off, or resets the BCDD solenoid on the side of the carburetor..
