Datsunsr20 Posted January 24 Report Share Posted January 24 Hi guys, Recently purchased a 620 truck and wanting when everything is ready change the engine. Ive a sr20det out of an s14. My main issue is what needs changed from the gear box back to make it work. Axel need changed? Just the differential? Any help or links would be great! Thanks Phil 1 Quote Link to comment
]2eDeYe Posted January 26 Report Share Posted January 26 I offer mounts to make this a bolt in swap fitment wise. You need to flip the center link and shorten the stock driveshaft for the longer SR transmission. My mounts, I have engine mounts, transmission crossmember, alternator relocation, fuel pump and MAF brackets. Center link flip 1 Quote Link to comment
Datsunsr20 Posted January 26 Author Report Share Posted January 26 Do you know what lsd would be best to fit? Quote Link to comment
]2eDeYe Posted January 27 Report Share Posted January 27 There isn't really a goo option for the stock H190 rear. Early Toyota 4x4 axles are about the correct width and have a large aftermarket following. 1 Quote Link to comment
Stoffregen Motorsports Posted January 27 Report Share Posted January 27 For the cost of a ultra-rare used Datsun LSD, you can do an entire Toyota axle swap and have your choice of limited slip, Detroit, air or electric locker or even a spool. Gear sets for an 8" Toyota diff cost about $200 and bearing kits around $100. Disc brake kits are available too, but most are junk, though there are a couple kits that work well and have a price to match. Quote Link to comment
Datsunsr20 Posted January 27 Author Report Share Posted January 27 2 hours ago, Stoffregen Motorsports said: For the cost of a ultra-rare used Datsun LSD, you can do an entire Toyota axle swap and have your choice of limited slip, Detroit, air or electric locker or even a spool. Gear sets for an 8" Toyota diff cost about $200 and bearing kits around $100. Disc brake kits are available too, but most are junk, though there are a couple kits that work well and have a price to match. Id imagine these parts aren't available in the uk! 1 Quote Link to comment
Stoffregen Motorsports Posted January 27 Report Share Posted January 27 (edited) Why not? Try here - https://www.roughtrax4x4.com/toyota-4x4-parts/axle-rear.html Edited January 27 by Stoffregen Motorsports Quote Link to comment
Datsunsr20 Posted January 27 Author Report Share Posted January 27 Id need to know which axel is needed too? That might be hard to get! Quote Link to comment
]2eDeYe Posted January 28 Report Share Posted January 28 Early Toyota 4x4 trucks and 4 runners up to 85. Later year axles can be shortened. Quote Link to comment
Stoffregen Motorsports Posted January 28 Report Share Posted January 28 (edited) Good info here - https://www.roundforge.com/articles/toyota-axle-widths/ Edit - this is info for north American vehicles. European vehicles had different names and more models to choose from. Edited January 28 by Stoffregen Motorsports Quote Link to comment
Stoffregen Motorsports Posted January 28 Report Share Posted January 28 WMS is "wheel mount surface" so when it says WMS to WMS, it means as measured from those two surfaces. 2 Quote Link to comment
FrankRizzo Posted January 29 Report Share Posted January 29 Some info here: https://datsuntrucks.com/datsun-620-lsd-differential-swap/ . 2 Quote Link to comment
