Mough Posted January 20 Report Share Posted January 20 So I'm posting this in hopes datzenmike see it. I have been looking at a post from years ago about changing ratios in the FS5W71 transmission. I understand dividing the drive and driven gears to get the ratio in the middle. What I don't get is how to come up with the final ratio I'm seeing on the right side. Anyone able to help on this? Next question, I have a 5 speed out of a 79 280zx. Is it possible to change only the 5th gear ratio to something a little closer to the .745 5th in the later trans. I know the synchronizer set up is different because mine has the odd ball 5th. Anyway is it possible and what does it take if it is? Quote Link to comment
datzenmike Posted January 20 Report Share Posted January 20 Box #1 is a mid ratio. Box #2 is a close ratio. As you can see the last gear sets (OUT) on the far right produce the OD (over drive) and they are the same 26/44 so swapping them does nothing. The left side (IN) will change every gear after it. Box #1 IN is 31/22 or 1.409. Multiply 1.409 X any other gear to the right gives the output ratio. Example 1.409 X 0.591 = .8327 or rounded to 0.833 OD or 5th gear Box #2 IN is 29/23 or 1.261 x the (OD 26/44) 0.591 = 0.745 There is no way to lift the 0.745 OD and place it into the mid ratio transmission. You could cut new gears with a 0.53 ratio something like 24/45 0.533 BTW... I have used a '79 zx mid ratio for years in both my truck and my 710 and really liked the ratios. I have a wide ratio in my car now for a faster revving first gear. 1 Quote Link to comment
Mough Posted January 20 Author Report Share Posted January 20 Thanks for getting back to me. I'm just trying to make sure I know what I have. Like I said it's supposed to be out of a 79 ZX. The more I look I don't think I will be able to just change 5th since mine has the steel synchro 5th. Correct me if I'm wrong on any of this. My tooth count for 5th is 19 on the main and 31 on the counter shaft. I havnt even seen this combo available when looking. Maybe it's because it is an odd ball and it's no longer available or wasn't commonly used so it's not available. I'm building this trans to put in my MG just really wanted a little taller 5th to bring RPMs down but want to keep everything else the same because it's close to the original MG ratios. Still would like to know how to correctly figure the final ratio for each gear if anyone can explain that. Quote Link to comment
datzenmike Posted January 20 Report Share Posted January 20 Box #1 IN far left side, is 31/22 or 1.409. Multiply 1.409 X any other gear to the right gives the output ratio. Example 1.409 X 0.591 (OD 5th) = .8327 or rounded to .833 OD or 5th gear Box #2 IN far left is 29/23 or 1.261 x 0.591 (OD 26/44 5th)= 0.745 Are you going to engine swap your MG to a L series engine????? Quote Link to comment
Mough Posted January 20 Author Report Share Posted January 20 Thanks for the info on how to figure the ratios. No keeping the MG engine, just wanted a 5 speed because it's geared to low to run interstate speeds. There's a company that builds an engine plate that takes the Nissan trans. No point in changing rear axle to a higher gear since I'm only working with 95hp so acceleration would suffer. Quote Link to comment
datzenmike Posted January 20 Report Share Posted January 20 19/31 is strange for the OD gears. This is a 0.6129 X the input of 1.409 = 0.863 OD Can you post a picture of your transmission??? Quote Link to comment
Mough Posted January 20 Author Report Share Posted January 20 I have it tore apart right now. What would you like to see and I'll take some pictures of it. Quote Link to comment
datzenmike Posted January 20 Report Share Posted January 20 The outer case halves specially right rear from the side. Quote Link to comment
Mough Posted January 20 Author Report Share Posted January 20 Can't figure out how to post them on here. Quote Link to comment
datzenmike Posted January 20 Report Share Posted January 20 You may have to get a free picture hosting site account such as imgur. (there are others) You store your picture there till needed. Then copy and bring here and paste it in your post. Quote Link to comment
mmerlinn Posted April 6 Report Share Posted April 6 On 1/19/2022 at 7:22 PM, Mough said: Is it possible to change only the 5th gear ratio to something a little closer to the .745 5th in the later trans. I know the synchronizer set up is different because mine has the odd ball 5th. Anyway is it possible and what does it take if it is? Yes, it is possible to change only the fifth gear ratio. Unfortunately, since you have the crush type syncros, there are only two ratios available, the common one (31x19 teeth, 0.613 ratio) and the rare one (38x22 teeth, 0.579 ratio). I sold both of my rare sets for $285 each in 2013 & 2014, so I cannot help you there. Quote Link to comment
mmerlinn Posted April 6 Report Share Posted April 6 On 1/20/2022 at 1:49 PM, datzenmike said: 19/31 is strange for the OD gears. This is a 0.6129 X the input of 1.409 = 0.863 OD Can you post a picture of your transmission??? Not strange for transmissions with crush type synchros. I have sold dozens of sets in the last 40 years and still have 6 sets in stock. Quote Link to comment
