Jp2 Posted January 12, 2022 Report Share Posted January 12, 2022 So I've been trying to remove my bezel for the gauge cluster because I'm hearing a ticking sound that indicates that my speedo cable is bad. Based on the title, you can see I haven't been able to get past step one lol. I have the manual that says that they're only two screws holding it in. I ended the screws and the bezel mostly comes out except for the bottom, It just gets stuck. Quote Link to comment
Thomas Perkins Posted January 13, 2022 Report Share Posted January 13, 2022 Check this video out... Quote Link to comment
NC85ST Posted January 13, 2022 Report Share Posted January 13, 2022 There are two clips that engage the bezel at the bottom. Pull straight out to remove. First picture is the 2 clips and the second is the bottom of the bezel. 2 Quote Link to comment
Jp2 Posted January 13, 2022 Author Report Share Posted January 13, 2022 1 hour ago, Thomas Perkins said: Check this video out... I did it, I guess it was just another case of very old and stuck clips Quote Link to comment
Jp2 Posted January 14, 2022 Author Report Share Posted January 14, 2022 23 hours ago, NC85ST said: There are two clips that engage the bezel at the bottom. Pull straight out to remove. First picture is the 2 clips and the second is the bottom of the bezel. Thank you for the help!!! Quote Link to comment
