Lonewolf1990 Posted January 7, 2022 Report Share Posted January 7, 2022 Just purchased a hot spark coil and I wanna install a new ballast resistor how do I wire a two prong resistor from the old 4 wire resistor Quote Link to comment
banzai510(hainz) Posted January 7, 2022 Report Share Posted January 7, 2022 (edited) whats the ohm resisitance on this coil? why you buy it? the stockcoil(1,6 ohm or close to it woud work fine with the orginal ballast.(1.6 ohm or close to it maybe this coil dont need a ballast if you know the ohm reading(say 3 ohms) whats the spec and instructions say I havent researched how the 4 contack ballast works HOT spark or Pertronix/Unilite conversion need 3 ohm resisitance when running otherwise the module can pop or read the instructions. Edited January 7, 2022 by banzai510(hainz) Quote Link to comment
