720kingkab Posted January 13 Author Report Share Posted January 13 or do you mean test module leads for 12v ? Quote Link to comment
720kingkab Posted January 13 Author Report Share Posted January 13 (edited) Edited January 13 by 720kingkab Quote Link to comment
datzenmike Posted January 13 Report Share Posted January 13 11 minutes ago, 720kingkab said: i did that with key on and off all wires have 11.44 volts when tested let me get a photo posted hang on Yah I guess they would read something though the coil primary. OK remove the wires from the positive terminals of both coils. Pull the wires off the module terminals and test for 12v. The one with 12v should be on the middle terminal. Quote Link to comment
720kingkab Posted January 13 Author Report Share Posted January 13 the pix with dmm are all with key in on position Quote Link to comment
720kingkab Posted January 13 Author Report Share Posted January 13 (edited) where is the device that turns off/on the 2nd coil on/off during deceleration or slowing ? is it on carb or throttle linkage and i failed to hook it up ? or it is stuck ? or maybe i have a vacuum line on wrong and when motor starts it is holding 2nd coil in off mode ? Edited January 14 by 720kingkab Quote Link to comment
720kingkab Posted January 13 Author Report Share Posted January 13 ok with both coil + wires removed and all 3 wires removed from ign module inside dist.. the center black wire with white stripe is only one with voltage it is 12.77v Quote Link to comment
720kingkab Posted January 13 Author Report Share Posted January 13 (edited) there is a vacuum hose going to a diaphragm on distributor body that vacuum hose that is taken off when timing is set Edited January 13 by 720kingkab Quote Link to comment
720kingkab Posted January 14 Author Report Share Posted January 14 like these hoses maybe ? Quote Link to comment
720kingkab Posted January 14 Author Report Share Posted January 14 maybe if i start engine then start pulling vacuum lines the 2nd coil might come on ? Quote Link to comment
datzenmike Posted January 14 Report Share Posted January 14 NO don't mess with it. If your module only has 3 terminals don't worry about the shut off. You don't have it. OK 12v on center wire so it's wired correctly. That's the vacuum advance hose. There is only a vacuum signal above idle so as long as you have 700-800 RPM idle then there's no need to remove it when setting the timing. Quote Link to comment
720kingkab Posted January 14 Author Report Share Posted January 14 (edited) the trucks runs and drives really nice . just hard to start when really cold maybe hard start related to 2nd coil no worky ? i will know more about new coil performance once i try and start when really cold tonight Edited January 14 by 720kingkab Quote Link to comment
720kingkab Posted January 14 Author Report Share Posted January 14 what is the part number for the distrib ign module thing incase it is broke Quote Link to comment
720kingkab Posted January 14 Author Report Share Posted January 14 maybe they have at oreilly Quote Link to comment
720kingkab Posted January 14 Author Report Share Posted January 14 (edited) E12-81 ? Edited January 14 by 720kingkab Quote Link to comment
720kingkab Posted January 14 Author Report Share Posted January 14 does anyone know a cross reference part number for the ign module ? Quote Link to comment
720kingkab Posted January 14 Author Report Share Posted January 14 cant see part number on ign module in this after market rebuilt cardone model either part # 31-622 Quote Link to comment
datzenmike Posted January 14 Report Share Posted January 14 The '81 ignition module is 22020-W0560 Quote Link to comment
720kingkab Posted January 14 Author Report Share Posted January 14 maybe this ? https://www.amazon.ca/Wells-JA113-Ignition-Control-Module/dp/B00G4UZEFQ Quote Link to comment
720kingkab Posted January 14 Author Report Share Posted January 14 https://www.ebay.com/itm/254246639956?hash=item3b3247d954:g:KkoAAOSwCtJcweJI Quote Link to comment
datzenmike Posted January 14 Report Share Posted January 14 7 minutes ago, 720kingkab said: maybe this ? https://www.amazon.ca/Wells-JA113-Ignition-Control-Module/dp/B00G4UZEFQ Unavailable. 1 minute ago, 720kingkab said: https://www.ebay.com/itm/254246639956?hash=item3b3247d954:g:KkoAAOSwCtJcweJI Says fits the 720. For that price get two. They are near $150. Dealer price $325!!! Quote Link to comment
720kingkab Posted January 14 Author Report Share Posted January 14 (edited) can i test mine ? to see if it works ? if possible how ? Edited January 14 by 720kingkab Quote Link to comment
