Richie Posted December 20, 2021 Report Share Posted December 20, 2021 hey. I need some help with the wiring for my EXR-200 Sony radio. I am using and aftermarket harness with a radio constant power wire and a antenna power wire. thank you. https://imgur.com/YLOdz1x Quote Link to comment
datzenmike Posted December 20, 2021 Report Share Posted December 20, 2021 I could tell you what's what if stock wiring.... after market wiring harness??? You would know more about this than me. Follow the Sony instructions for wiring. The power lead to the antenna is for an electric extendable antenna. The 620 antenna is fixed in place. 1 Quote Link to comment
thisismatt Posted December 20, 2021 Report Share Posted December 20, 2021 Aside from the speakers, there are only three wires to hook up. Ground, constant power, and switched/ignition power. Constant is usually yellow and switched is usually red. 1 Quote Link to comment
thisismatt Posted December 20, 2021 Report Share Posted December 20, 2021 I guess you could also have an illumination wire for night time 1 Quote Link to comment
Richie Posted December 21, 2021 Author Report Share Posted December 21, 2021 On 12/20/2021 at 12:14 PM, datzenmike said: I could tell you what's what if stock wiring.... after market wiring harness??? You would know more about this than me. Follow the Sony instructions for wiring. The power lead to the antenna is for an electric extendable antenna. The 620 antenna is fixed in place. well I have the old harness. what i guess i am really looking for is what gives the radio power and which pin on the back would it be according to the old harness. Also if you have a picture of what the connectors look like on the pigtail for the radio, I know they are pins I could look in my bag of old harness and see if I can find it. Quote Link to comment
Ooph! Posted December 21, 2021 Report Share Posted December 21, 2021 Sony has the wiring info but you need to know how many wires it has to select the correct info https://www.sony.com/electronics/support/in-car-receivers-mobile-tape-players/exr-200/articles/00028631 1 Quote Link to comment
Richie Posted December 23, 2021 Author Report Share Posted December 23, 2021 Am i tripping or do you guys see 10 pins? https://imgur.com/a/sNLzm5I Quote Link to comment
datzenmike Posted December 23, 2021 Report Share Posted December 23, 2021 2 for the Left 2 for the Right 12v power constant 12v switched Ground Switched on for external sub amp 2 for illumination 1 Quote Link to comment
Richie Posted December 23, 2021 Author Report Share Posted December 23, 2021 5 minutes ago, datzenmike said: 2 for the Left 2 for the Right 12v power constant 12v switched Ground Switched on for external sub amp 2 for illumination now is this starting from right to left of the picture? Quote Link to comment
datzenmike Posted December 23, 2021 Report Share Posted December 23, 2021 Just a guess. The 620 wiring would be Blue/White for switched power and two wires for the ONE mono speaker, one of these is grounded. The Sony will need some creative wiring and extra speakers. 1 Quote Link to comment
Richie Posted December 23, 2021 Author Report Share Posted December 23, 2021 (edited) 7 minutes ago, datzenmike said: Just a guess. The 620 wiring would be Blue/White for switched power and two wires for the ONE mono speaker, one of these is grounded. The Sony will need some creative wiring and extra speakers. yea i think i am just going to ground it, and switch the constant power wire from pin to pin until I get something. Thanks for the help. Before i took the wires out I remember he just had it all taped up together. Also do you know if there is a thread on here about 620 front brakes i can reference to? apparently before the brakes went out, it would pull to the right. I Bought drums, hardware, and wheel cylinders (they were leaking) recently to replace the old ones. Edited December 23, 2021 by Richie Quote Link to comment
Ooph! Posted December 23, 2021 Report Share Posted December 23, 2021 (edited) From https://elektrotanya.com/sony_exr-200_sm.pdf/download.html Edited December 23, 2021 by Ooph! 1 2 Quote Link to comment
datzenmike Posted December 23, 2021 Report Share Posted December 23, 2021 I would not be applying power randomly to pins in the back. 1 Quote Link to comment
