H-BRATSON Posted December 6, 2021 Report Share Posted December 6, 2021 Having issues with my lighting. Light relay buzzing/screaming at me when hazard switch activated. After further research found it may be a ground. Following the circuit in the diagram, it shows that it may be grounded through the dimmer switch. If I am incorrect please let me know thank you!! Quote Link to comment
datzenmike Posted December 6, 2021 Report Share Posted December 6, 2021 The dimmer only dims the dash lights, heater and oil/volts gauges. Has no connection to anything else. The hazard or 4 way flasher only affects the 4 turn signal/brake bulbs. The headlight relay is mounted above the 2 headlight fuses on the far right of the fuse box. It should only click when hi/low is selected. Put you finger on the relay that is buzzing and you'll feel it. A buzzing relay is usually the auto choke heater relay located above the right side kick panel beside the glove box. Quote Link to comment
H-BRATSON Posted December 6, 2021 Author Report Share Posted December 6, 2021 I will look into that! Thanks Mike Quote Link to comment
