Ricky-Ticky Posted November 25, 2021 Report Share Posted November 25, 2021 So about a year ago I bought this 83 Nissan kingcab. The previous owner put 32” tires on it with stock suspension. And the upper ball joints went out. While replacing my ball joints one got stuck in the passenger side. I’ve battled getting it out for days. So I’m to the point where I’m ready to just replace the spindle. But I can’t find any replacements for the 4wd version. Any one know of another truck or car that could be compatible. Or somewhere I could find oem parts? Any help appreciated. Quote Link to comment
datzenmike Posted November 25, 2021 Report Share Posted November 25, 2021 That is the broken upper ball joint? They don't get stuck. They are a taper fit and naturally hard to separate. It has to be driven out in the upwards direction, or to the left in that picture. Rent a ball joint separator like this... Many auto parts stores do this. Quote Link to comment
bottomwatcher Posted November 26, 2021 Report Share Posted November 26, 2021 After you break that little tool either try a larger two prong puller or take it to someone with a hydraulic press. The rest looks salvageable and you know it fits. Quote Link to comment
Bleach Posted November 27, 2021 Report Share Posted November 27, 2021 To get OEM parts like that spindle, I would go first to a wrecking yard. The Self-Pull wrecking yards are fairly reasonable on prices and they publish their price lists so you know what you're going to pay ahead of time. Search in your area using Row52.com I don't know if there were differences in the 720 spindles. If not, then any 4x4 1980-85 should work. Some 1986 trucks were 720 model and some were Hardbody models. Quote Link to comment
bottomwatcher Posted November 28, 2021 Report Share Posted November 28, 2021 There is nothing wrong with that spindle except the remains of the balljoint needs to be pressed out. An air chisel with a point bit might work or a large punch, 3lb hammer, a little heat might do the trick too. Quote Link to comment
