Drive shaft ID
  • Replies 5
From '74 through '79 the front ones should all be the same length. The rear one depends on the frame length. Short and long frames.
The '73 used a short 26" 4 speed so the front would be longer than the later 620s might even be a match for the 521 L16 .
Sorry, don't have any numbers.
Only the '70-'72 L16 PL521 had the bolt on flange on the transmission output spline. The J13 powered 520 and '69 L521 had a single driveshaft so didn't have the bolt on output because the transmission and differential have to move independent of each other.
The PL521 transmission is identical to the 510 wagon 4 speed including the gearing, other than this flange.
  • Thanks 1
  • 2 months later...
