Drago Posted November 17, 2021 Report Share Posted November 17, 2021 I just got a 1985 300zx and I wanted to put on some exterior parts like fender flares, front bumper, and spoiler. Is there a good website I can use to find these parts? Also do some 240z parts fit this car as well? Quote Link to comment
Bleach Posted November 18, 2021 Report Share Posted November 18, 2021 Older Z parts are generally not going to be good options. Your model of car was 1984-89 and more specifically, just 1984 and 1985. Older Z-cars do not have bolt-on fender flares from the factory. You could buy and install aftermarket flares and cut your stock flares off. Bumpers, no. Commonly Z31 people will convert to the later Z31 body panels for a more clean and modern look. 1987-89 Front bumper, headlights, hood, and front fenders will all bolt on with only a few minor modifications needed for the headlight mounting. The rear flares will not match but you can go aftermarket for those. As for rear spoiler, the shape of the Z31 hatch is different than all other Z-cars so the 1986-89 factory spoiler is your best bet. The R200 differential is the same on the 1975-83 Z cars, at least those that had an R200 and not an R180. If you want to go with lower gearing for more torque, you can try to find a 3.9 ratio R200 in the 1981-83 280ZX non-turbo. 1 1 Quote Link to comment
