CEAZERKHAN Posted November 15, 2021 Report Share Posted November 15, 2021 Its getting cold where I live now and my b210 is misfiring/rich on cold start, its fine after it warms up. I've seen people say running rich in cold weather in normal? Is it normal? could that be causing the misfire? what could be causing the misfire? Quote Link to comment
datzenmike Posted November 15, 2021 Report Share Posted November 15, 2021 Back fire through the carburetor??? Probably from a lean condition. Cold engines like a rich mixture because cold air doesn't evaporate the gas droplets very well. This is why carburetors have a choke. Sounds like yours may not be working. When the engine is cold from over night. Take the top of the air filter and look down inside. The choke flap should be mostly open like this... Have someone step down on the gas a couple of times. The choke should instantly snap closed like this... Does it??? 1 Quote Link to comment
CEAZERKHAN Posted November 16, 2021 Author Report Share Posted November 16, 2021 5 hours ago, datzenmike said: Back fire through the carburetor??? Probably from a lean condition. Cold engines like a rich mixture because cold air doesn't evaporate the gas droplets very well. This is why carburetors have a choke. Sounds like yours may not be working. When the engine is cold from over night. Take the top of the air filter and look down inside. The choke flap should be mostly open like this... Have someone step down on the gas a couple of times. The choke should instantly snap closed like this... Does it??? i will have to see in the morning, there's no back fire through the carb. ill update if the flap closes or not tomorrow... Quote Link to comment
datzenmike Posted November 16, 2021 Report Share Posted November 16, 2021 Miss fire, (sorry) still, probably the choke either set too lean or not working. 1 Quote Link to comment
CEAZERKHAN Posted November 16, 2021 Author Report Share Posted November 16, 2021 13 hours ago, datzenmike said: Miss fire, (sorry) still, probably the choke either set too lean or not working. well i was able to quickly check this morning, took off the top of the air cleaner and looked down in there and the flap was open so i pumped the gas a couple times and it closed, I (currently) dont daily it so i had no time to start and see if it helped or stayed shut. will have to check better later today when in not on a time crunch. Quote Link to comment
datzenmike Posted November 16, 2021 Report Share Posted November 16, 2021 It will likely open slightly once started, that's normal. The idle should also be faster reducing as the engine warms up. By loosening 3 screws the choke heater is adjustable to make richer or leaner. 1 Quote Link to comment
CEAZERKHAN Posted November 16, 2021 Author Report Share Posted November 16, 2021 24 minutes ago, datzenmike said: It will likely open slightly once started, that's normal. The idle should also be faster reducing as the engine warms up. By loosening 3 screws the choke heater is adjustable to make richer or leaner. ill have to start tinkering on it when i get home later👍 Quote Link to comment
datzenmike Posted November 16, 2021 Report Share Posted November 16, 2021 Note where it is so you can go back. Try slightly richer. The engine should also rev up to a faster idle. 1 Quote Link to comment
CEAZERKHAN Posted November 18, 2021 Author Report Share Posted November 18, 2021 On 11/16/2021 at 1:04 PM, datzenmike said: Note where it is so you can go back. Try slightly richer. The engine should also rev up to a faster idle. its fixed now, there were some lines that got unplugged, got some fresh lines and tighten down some bolts that shouldn't of been that loose, but it runs perfect now, thank you for all the help!👍 Quote Link to comment
