Motor mounts
athoose
I got some motor mounts awhile back off rock auto but they don't look like the current ones. I did find something that looks correct at AutoZone. Don't really want to but it looks like i could just drill some holes for the rock auto ones. Thoughts?
Rock auto...
Current ones look like these.
  • Replies 14
I'm curious if those from autozone are correct....
It says they are correct for the 521 and the 620.... I could have sworn when I bought the ones for my 521 from autozone they looked correct in the picture but were not right....
At the time I believed they were for a 720.....
This was a few years ago so they may have corrected the error....
The ones I received were taller and bigger than the stock ones....
After a couple failed motor mount purchases, and due to the fact the correct 521 motor mounts didnt seem to be available I ended up using them by redrilling 2 holes in the mount to be able to bolt it to the frame, and I had to shorten the metal brackets attached to the engine....
I can check later when I get home, I should still have the boxes with the part number.....
Well I was able to look up the mount I am currently using....
It is the a6353..... not correct for your application so dont use it.. but it is listed for the 521, again not correct..
I hate the pictures,  if you look up same part on different sights sometimes the picture Is different ....
I would probably try the autozone ones first, 2532/2533.... not really sure why 2 different part numbers...
Not sure if the 620 had 2 different ones or not....
Atleast with autozone you can check them and return without a shipping charge....
Even now cross checking gets confusing.....
Just take some reference measurements to compare....
Goodluck....
On 11/10/2021 at 1:21 PM, ]2eDeYe said:
Just a little shorter, like 3/16"
I thought this too but the l16 mounts i got from rockauto were the same height as my l20b mounts even though they were obviously a diffrent style. If the ones you end up getting are a bit shorter I would like to know where you got them / what brand or part number.
I read through the form again thought you were talking about the 620 l16 mounts when you said 3/16 shorter; which is about the difference i measured from my 72 620 mounts vs my 77 mounts. the mounts i got were the same as op. will have to try some 521 mounts, thanks.
went through my post history to get my measurements:
l20b mounts: Roughly 1.9" L16 mounts: Roughly 1.5"
so 521 might be in-between those two. if i get some ill update.
Edited by Moist Lightning
