Mspencer Posted October 23, 2021 Report Share Posted October 23, 2021 I have not worked on these SU R16 before so i wanted to check in before moving forward. Each float has liquid in them just a little (so i think) i cleaned up the floats and looked at each under a magnifying glass but don't see any holes? i have let then sit on a paper towel for 5 min on each side and no wet spots on the towel. So, i assume the floats should be empty, If i need new floats i am not sure where to get them? i have only found Kits that start around $400 that include new floats. the kits seem overkill for floats with a leak. thanks Quote Link to comment
datzenmike Posted October 23, 2021 Report Share Posted October 23, 2021 How are you determining that they have something i them?? Shake them? Could it be just some solder??? Quote Link to comment
Mspencer Posted October 23, 2021 Author Report Share Posted October 23, 2021 54 minutes ago, datzenmike said: How are you determining that they have something i them?? Shake them? Could it be just some solder??? Shanking them, sure sounds like liquid, i will weigh them and see if there is much of a difference. Quote Link to comment
datzenmike Posted October 23, 2021 Report Share Posted October 23, 2021 Lead is bound to drip in during the soldering process. Quote Link to comment
Mspencer Posted October 23, 2021 Author Report Share Posted October 23, 2021 22 minutes ago, datzenmike said: So, there is a small bit of solder on the top of each float, looks factory. anyway i used my smallest drill to drill a hole at that point and yes, gas came out. there must be a tiny hole at the seam on each float. one float weighed 20 grams the other 25 grams. empty they are 14 grams. Quote Link to comment
datzenmike Posted October 24, 2021 Report Share Posted October 24, 2021 Pretty definitive. Re solder them. Quote Link to comment
Mspencer Posted October 24, 2021 Author Report Share Posted October 24, 2021 16 minutes ago, datzenmike said: Pretty definitive. Re solder them. Done! Thanks for walking me through it. Quote Link to comment
