No spark, need suggestions
kudu
3 minutes ago, datzenmike said:
A random problem is the worst thing to try and fix. Do you have a spare coil? Just replace it and see if the problem goes away. If not, DON'T run out and buy one. Next time it quits pour ice cold water over the coil body to cool it. If in 10 min it starts you have confirmation.
Yes I have the coil that was originally in the car. This one is a (only the best quality lol) car quest one. I was thinking of just switching back to the old one and running it and then turning it off and trying to start it again and see if it’s just the shitty aftermarket one.
  • Replies 52
2 hours ago, datzenmike said:
Never replace a stock part unless absolutely sure it's bad and then never throw away.
I was just doing it to try and eliminate the problem while diagnosing this spark problem. If this problem still persists with the stock part what would be the next steps
edit: works good with the old coil.
Edited by kudu
