dans521 Posted October 10, 2021 Report Share Posted October 10, 2021 While dojng a ka24 swap on my 521, i wanted better gear ratio, h190s arr impossible to find in new zealand, but c200s are every where so i picked one up and just need to shorten it After some research, it looked like the axles were the same shaft soze and spline count depending on year. Turns out they are, so ill be using h190 axles in a c200 diff with the better brakes also, just in the process of swapping the backing plates if possible, waiting in a apress to arrive Reason im doing it this way, is i can shorten the housing at home but the axles were the expensive part and im not made of money TLDR: h190 and c200 alxes are the same size Quote Link to comment
datzenmike Posted October 12, 2021 Report Share Posted October 12, 2021 Same spline size then? Quote Link to comment
dans521 Posted October 16, 2021 Author Report Share Posted October 16, 2021 On 10/13/2021 at 8:37 AM, datzenmike said: Same spline size then? Yup, even uses the same bearings Quote Link to comment
Lockleaf Posted November 4, 2021 Report Share Posted November 4, 2021 Very nice bit of research. Take a bunch of pics and post it up as you build the custom rearend. Quote Link to comment
