Veraciousreasoning Posted October 7, 2021 Author Report Share Posted October 7, 2021 1 hour ago, bottomwatcher said: 1980 you have the L motor. I am no expert on them. Where are the inlet and outlet hoses located? You do want to make sure you get a match because only a few inches movement of the hose neck on the radiator turns into a major pain in the ass. Top right and bottom left. Quote Link to comment
bottomwatcher Posted October 7, 2021 Report Share Posted October 7, 2021 17 minutes ago, Veraciousreasoning said: Top right and bottom left. Ok. Regular 720 z radiator is inlet and outlet passenger side. You are going to have to research. Quote Link to comment
bottomwatcher Posted October 10, 2021 Report Share Posted October 10, 2021 On 10/7/2021 at 10:44 AM, bottomwatcher said: Ok. Regular 720 z radiator is inlet and outlet passenger side. You are going to have to research. Just had a though. Sid you replace the rad cap? Quote Link to comment
Veraciousreasoning Posted October 11, 2021 Author Report Share Posted October 11, 2021 7 hours ago, bottomwatcher said: Just had a though. Sid you replace the rad cap? No I have not. It seems to have good pressure. When I run the truck and let it cool down for a bit when I release the cap you can hear the pressure so I assumed its good. I guess I can try to replace it. Quote Link to comment
