tiny Posted September 28, 2021 Report Share Posted September 28, 2021 Drove around 200km off-road with my 81 720 2WD without any issues, but once we hit an intersection we realized that when the right turn signal is flipped on, it just sticks and doesn’t blink (the green arrow just stays illuminated). Doesn’t happen on the left side. Haven’t really poked around, just curious as to if anyone else has run into a similar issue before! Thanks Quote Link to comment
captain720 Posted September 28, 2021 Report Share Posted September 28, 2021 Yes usually that means a bulb is not lit due to a bad bulb or wiring to it, potentially a ground issue as well. The mechanical flashers require a bulb to be lit to flash, if the system doesn't have enough draw than it just stays on instead of flashing 1 Quote Link to comment
