Phil P Posted September 26, 2021 Report Share Posted September 26, 2021 Hey everyone I'm new and need advice. I have a L20B and 5 speed transmission Removed from 1980 King cab 4X4 720. Want to put it in my 1967 single head light 520. I understand that a L20B will fit? Looks like the oil pan is going to have to be changed? TY Phil 1 Quote Link to comment
datzenmike Posted September 26, 2021 Report Share Posted September 26, 2021 The 520 is a very tight fit for an L series engine. The frame engine mount locations are set up for the J13 which will not take an L series engine. You'll need to cut them off and move them. You will need, for convenience, the oil pan from a 521 with an L16 engine. As the 520/521/620 and 720 are somewhat similar front ends with the steering in the front, and as you are completely changing the engine mount locations you may be able to use the 720 oil pan. The 4x4 does not have a speedometer drive in the transmission nor can you fix this without swapping a 2wd tail and worm gear onto the main shaft onto it. Measure the transmission length. The 720 had two different lengths. If you have the 26" 'shorty' you may not have to modify the driveshaft length. Quote Link to comment
Phil P Posted September 26, 2021 Author Report Share Posted September 26, 2021 It appears the 720 oil pan on the 4X4 is different from 720 2wd.. The oil pan is offset and larger on the drivers side, in the rear. It is to clear the front differential and front drive shaft. The dipstick is in between the engine and the firewall into the back of the engine. 1) Will that dipstick work with the 521 oil pan? 2) If I change oil pans, will I need to replace the pick for the oil pump? TY Phil 1 Quote Link to comment
Charlie69 Posted September 26, 2021 Report Share Posted September 26, 2021 (edited) Oil pickups match oil pans they are a set so to say. As far as the dip stick and tube compare the 521 with the 720. I installed a L20B automatic in my 66 520 and it is well documented in my 520 build thread orange link in my posts. Edited September 26, 2021 by Charlie69 Quote Link to comment
Phil P Posted September 28, 2021 Author Report Share Posted September 28, 2021 wow ty that's going to help I've got about a bunch of question? 1 Quote Link to comment
Charlie69 Posted September 29, 2021 Report Share Posted September 29, 2021 (edited) Ask away! The reason for the custom firewall is to be able to remove the valve cover with th motor in the truck. Do you have the 720 chassis? Edited September 29, 2021 by Charlie69 Quote Link to comment
Charlie69 Posted September 29, 2021 Report Share Posted September 29, 2021 There have been a couple Z24 5speed swaps into the 320. Quote Link to comment
Phil P Posted September 30, 2021 Author Report Share Posted September 30, 2021 Ok Yes sir I have the chassis I have a L-16 oil pan on the way for the L20B. I have the long tail section 5sp. transmission, looking for a shorty. The 66 520 is very cool. TY 1 Quote Link to comment
Charlie69 Posted October 1, 2021 Report Share Posted October 1, 2021 (edited) Do a complete chassis swap. I did a 1980 720 chassis swap to my 66 520. Best upgrade I did. It gets you away from King pins gives you disk brakes and removable trans cross member. also gives you rag joint steering column and the idler arm and steering gear box is outside the frame rails. This is also documented in my 520 build thread. Wayno has done several 720 to 520/521 chassis swaps. Wayno is a great source for information. Edited October 1, 2021 by Charlie69 1 Quote Link to comment
Phil P Posted October 1, 2021 Author Report Share Posted October 1, 2021 Chassis is king cab with rotten floor, and back of cab. The frame is also rotten from front middle of door to tail lights. 1 Quote Link to comment
Charlie69 Posted October 3, 2021 Report Share Posted October 3, 2021 Section the front half of the 720 frame to the rear half of the 521. The front half is where all the benifits are on the 720 frame. Quote Link to comment
datzenmike Posted October 3, 2021 Report Share Posted October 3, 2021 Best to cut behind the torsion bars. You can weld up the frame rot once cut off. 1 Quote Link to comment
Phil P Posted October 4, 2021 Author Report Share Posted October 4, 2021 The 720 was in a wreck and damaged the passengers side frame. 1 Quote Link to comment
