banzai510(hainz) Posted September 27, 2021 Report Share Posted September 27, 2021 The Datsun Certified mechanic is more likely to know where to find this kit than us on Ratsun as most just polish those carbs up then throw then in the river. If anything a weber DGV carb I never heard of a electric and manual choked carb but you said you worked on carbs before. I I guess I dont know. 1 Quote Link to comment
datzenmike Posted September 27, 2021 Report Share Posted September 27, 2021 Hainz those wires are for the solenoid on the left side. easily mistaken for an electric choke. It's an early emissions thing somewhat like a later BCDD Quote Link to comment
Arifaeth Posted September 27, 2021 Author Report Share Posted September 27, 2021 8 minutes ago, datzenmike said: Hainz those wires are for the solenoid on the left side. easily mistaken for an electric choke. It's an early emissions thing somewhat like a later BCDD 58 minutes ago, banzai510(hainz) said: The Datsun Certified mechanic is more likely to know where to find this kit than us on Ratsun as most just polish those carbs up then throw then in the river. If anything a weber DGV carb I never heard of a electric and manual choked carb but you said you worked on carbs before. I I guess I dont know. Yes, I was mistaken on the choke part, as I hadn't started going through it very much, and my brother had taken a look at it before me. Quote Link to comment
Arifaeth Posted September 27, 2021 Author Report Share Posted September 27, 2021 1 minute ago, Arifaeth said: Yes, I was mistaken on the choke part, as I hadn't started going through it very much, and my brother had taken a look at it before me. I just figured you guys would have rebuilt yours carbs in the past, as it's a good maintenance task to do anytime a carb sits dry for more than a year or two Quote Link to comment
banzai510(hainz) Posted September 27, 2021 Report Share Posted September 27, 2021 (edited) I tried once and it exploded like a rebix cube on the bearing/spring part. Stock carb are more elaberate. the Weber DGV is simplicity at its finest ,even the rebuild kit is so EZ. Some people are good at it I was not . and when they do it still dont run right. If one can find a place that has the rebuilt one in stock and you turn your old one in mite be better. ebay might have some option on the rebuild kits I used to buy the kits but said hell with it once I got a weber, plus you can use the stock linkage from the Hitachi to bolt the linkage up to the DGV. Might have to shim but its doable as for the idle one can try to adjust the mixture screw at the base of the carb with the tension spring on there. turn it in or out till it runs better, and then try adv or retard the dist to get it running where you want it Edited September 27, 2021 by banzai510(hainz) Quote Link to comment
Arifaeth Posted September 27, 2021 Author Report Share Posted September 27, 2021 3 minutes ago, banzai510(hainz) said: I tried once and it exploded like a rebix cube on the bearing/spring part. Stock carb are more elaberate. the Weber DGV is simplicity at its finest ,even the rebuild kit is so EZ. Some popel are good at it I was not . and when they do it still dont run right. If one can find a place that has the rubuilt one in stock and you turn your old one in mite be better. ebay might have some option on the rebuild kits I used to buy the kits but said hell with it once I got a weber, plus you can use the stock linkage from the Hitachi to bolt the linkage up to the DGV. Might have to shim but its doable At this point in time, (I don't want to sound rude or anything) I'm only looking for of someone knows where to find a rebuild kit. I'm not wanting Any ideas for swapping it with something, or anything like that, I purely just need new gaskets, and would rather spend $30 on new gaskets, than $180 or more on a new carb. Quote Link to comment
banzai510(hainz) Posted September 27, 2021 Report Share Posted September 27, 2021 https://www.partsgeek.com/catalog/1970/nissan/521_pickup/carburetion/carburetor_repair_kit.html I picked 1970 but not sure what yours is but since its a manual its under 1971 Quote Link to comment
Arifaeth Posted September 27, 2021 Author Report Share Posted September 27, 2021 10 minutes ago, banzai510(hainz) said: https://www.partsgeek.com/catalog/1970/nissan/521_pickup/carburetion/carburetor_repair_kit.html I picked 1970 but not sure what yours is but since its a manual its under 1971 Thanks man! I appreciate it, I had found one on rockauto, but i don't know how to order from them, or if they're parts are any good. Figured I'd end up talking to a guy I know, or calling Nissan 😂😂 1 Quote Link to comment
banzai510(hainz) Posted September 27, 2021 Report Share Posted September 27, 2021 calling Nissan is a waist of time, You just want to get abused. They dont want to deal with you. Believe me. 1 Quote Link to comment
Arifaeth Posted September 27, 2021 Author Report Share Posted September 27, 2021 1 hour ago, banzai510(hainz) said: calling Nissan is a waist of time, You just want to get abused. They dont want to deal with you. Believe me. Luckily I've got friends over at my local Nissan 😂 1 Quote Link to comment
banzai510(hainz) Posted September 27, 2021 Report Share Posted September 27, 2021 (edited) Here they pretty much dont want to deal with anything under 2012 2002 and definitly not 1972. they just scrap alot of parts taking up space. Edited September 27, 2021 by banzai510(hainz) 1 Quote Link to comment
datzenmike Posted September 27, 2021 Report Share Posted September 27, 2021 Nissan never recovered after Renault bought them in '96? Last few times I went I gave hem a part number and the first god damn thing out of their mouths was "What vehicle is this for" OR "What's the VIN?" followed by "we don't go back that far" OR "NLA". (mostly NLA) Not one in any way offered help or suggestions for someone with a 45 year old Nissan. They just couldn't be bothered with any kind of challenge other than punching in a VIN code. Fuck Nissan and their useless lazy millennial workers. Compare that to '98 when the parts manager spent 2 hours looking up flywheels and transmission input shaft comparisons to safely hazard that a Z24 pilot bushing should work on a '78 L20B 620 truck. And it did. Once they moved to their new location there was a woman parts manager who couldn't do anything without VINs. "You want fries with that"????????? 1 Quote Link to comment
