KAIKZ720 Posted September 5, 2021 Report Share Posted September 5, 2021 Does anyone know where I could get a cam with .475 lift for the Z24 2.4L motor? I'm looking for a more "snappy" type of power because right now I am lacking low end power. 1 Quote Link to comment
Charlie69 Posted September 5, 2021 Report Share Posted September 5, 2021 Have one ground. Quote Link to comment
datzenmike Posted September 5, 2021 Report Share Posted September 5, 2021 The Z series cams have the same specs as the earlier L series for stock lift and duration. The L series has enough 'meat' on the base circle that you can grind it down and get that much lift. I have one with 0.480", stock is 0.415 but this does not include the valve clearance loss. I don't think the Z series cams are as thick and may not allow it. Lift of 0.480 is very close to where the valve spring will bottom out or 'stack'. There is huge support for the Z series in the Philippines, or was. Just know that the Z series port design is not good for making easy performance improvements like the earlier L series. Basically is does not breath very well above 4K. Red line is 6,250 so aim for good flow up to that. It does have a desirable hemi combustion chamber, cross flow ports and dual plugs. Z series are perfect engines for a turbo. 1 1 Quote Link to comment
KAIKZ720 Posted September 5, 2021 Author Report Share Posted September 5, 2021 1 hour ago, datzenmike said: The Z series cams have the same specs as the earlier L series for stock lift and duration. The L series has enough 'meat' on the base circle that you can grind it down and get that much lift. I have one with 0.480", stock is 0.415 but this does not include the valve clearance loss. I don't think the Z series cams are as thick and may not allow it. Lift of 0.480 is very close to where the valve spring will bottom out or 'stack'. There is huge support for the Z series in the Philippines, or was. Just know that the Z series port design is not good for making easy performance improvements like the earlier L series. Basically is does not breath very well above 4K. Red line is 6,250 so aim for good flow up to that. It does have a desirable hemi combustion chamber, cross flow ports and dual plugs. Z series are perfect engines for a turbo. Thank you for always coming in for help 🙏🏽 1 Quote Link to comment
