Elye Posted August 24, 2021 Report Share Posted August 24, 2021 the front differential and transfer case is good what else could cause 4x4 not to work cv axle ? 1 Quote Link to comment
Stinky Posted August 24, 2021 Report Share Posted August 24, 2021 Hubs. Put it in 4x4, jack up each corner and then spin the wheel and see where the shaft turns, or not. If the shaft turns, that is good... as far as the hub goes. If the shaft turns, your case is not engageing. If it doesn't turn, the hub is bad, 2 Quote Link to comment
