Bp72D521 Posted August 4, 2021 Report Share Posted August 4, 2021 I have a 72 521 with the Mklotz balljoint conversion and a big brake kit off the d21 hard body v6, and it just doesn't have the stopping power. What sort of brake boosters and master cylinder kits are people running on d21 front brake swaps? Would using the d21 booster work and work well? Also it is a stick, so there is a clutch cylinder next to the old brake master. 1 Quote Link to comment
]2eDeYe Posted August 4, 2021 Report Share Posted August 4, 2021 I am running a 620 booster (stock in my truck) and a 280 15/16 master. Works great. D21 Booster and master should also work great if you can fit them in there. The early 620 has a small diameter booster for tight spaces. 1 Quote Link to comment
]2eDeYe Posted August 4, 2021 Report Share Posted August 4, 2021 ...and welcome 1 Quote Link to comment
Stoffregen Motorsports Posted August 4, 2021 Report Share Posted August 4, 2021 If you have good fabrication skills, you could use the large booster by moving the clutch master/pedal assembly over a bit and mount the large booster directly to the firewall, instead of using that long booster mount, like on the later 620s. 1 Quote Link to comment
thisismatt Posted August 4, 2021 Report Share Posted August 4, 2021 Or do this... https://ratsun.net/topic/69604-521-anyone-ever-put-a-brake-power-booster-in-one/?do=findComment&comment=1388959 1 Quote Link to comment
Charlie69 Posted August 5, 2021 Report Share Posted August 5, 2021 Go automatic trans and loose the clutch master, this opens up many possibilities. Quote Link to comment
thisismatt Posted August 5, 2021 Report Share Posted August 5, 2021 7 minutes ago, Charlie69 said: Go automatic trans and loose the clutch master, this opens up many possibilities. Collectively we'll just pretend you didn't say that 2 2 Quote Link to comment
mainer311 Posted August 5, 2021 Report Share Posted August 5, 2021 It’s “lose,” not “loose.” 1 Quote Link to comment
datzenmike Posted August 5, 2021 Report Share Posted August 5, 2021 (he's been talking to a Canadian....) Quote Link to comment
Charlie69 Posted August 5, 2021 Report Share Posted August 5, 2021 (edited) 5 hours ago, mainer311 said: It’s “lose,” not “loose.” Thank you you are better than spell check! LOL Edited August 5, 2021 by Charlie69 Quote Link to comment
datzenmike Posted August 5, 2021 Report Share Posted August 5, 2021 20 hours ago, Stoffregen Motorsports said: If you have good fabrication skills, you could use the large booster by moving the clutch master/pedal assembly over a bit and mount the large booster directly to the firewall, instead of using that long booster mount, like on the later 620s. The 620 booster spacer isn't much different than the B-210 but the 720 spacers are really huge. 2 Quote Link to comment
mainer311 Posted August 5, 2021 Report Share Posted August 5, 2021 I wish the brake booster worked with sidedrafts. No way it would fit without serious modification. 1 Quote Link to comment
Stoffregen Motorsports Posted August 5, 2021 Report Share Posted August 5, 2021 Right, the 720 spacer is huge. I've moved pedals before and it really isn't that difficult. 2 Quote Link to comment
Charlie69 Posted August 5, 2021 Report Share Posted August 5, 2021 Remote booster like Wayno did years ago. Quote Link to comment
d.p Posted August 5, 2021 Report Share Posted August 5, 2021 @datzenmike Can you temporarily ban @charlie69 from posting in the 521 section? I swear some of his advice is so wrong it will never be right in a million years. Swtich to automatic? I mean that is sacrilegious at best. 1 2 Quote Link to comment
datzenmike Posted August 5, 2021 Report Share Posted August 5, 2021 15 hours ago, Charlie69 said: Go automatic trans and loose the clutch master, this opens up many possibilities. 42 minutes ago, d.p said: @datzenmike Can you temporarily ban @charlie69 from posting in the 521 section? I swear some of his advice is so wrong it will never be right in a million years. Swtich to automatic? I mean that is sacrilegious at best. I asked Hillary to look into this. She said she might have a solution not involving being banned. I think that fair to Charlie. 1 1 Quote Link to comment
thisismatt Posted August 5, 2021 Report Share Posted August 5, 2021 7 minutes ago, datzenmike said: I asked Hillary to look into this. She said she might have a solution not involving being banned. I think that fair to Charlie. 2 1 1 Quote Link to comment
mainer311 Posted August 5, 2021 Report Share Posted August 5, 2021 (edited) 1 hour ago, datzenmike said: I asked Hillary to look into this. She said she might have a solution not involving being banned. I think that fair to Charlie. I guess that's the end of Charlie. Edited August 5, 2021 by mainer311 2 Quote Link to comment
Charlie69 Posted August 5, 2021 Report Share Posted August 5, 2021 (edited) I have been here much longer than d.p so I really do not think I will be going any where. d.p try contributing instead of whining. By the way when you d.p have over 40 plus years experience in 320s, 520s, & 521s then talk to me. I guess we have another Ratsun member with sand in his vagina! LOL Edited August 16, 2021 by Charlie69 2 1 3 Quote Link to comment
datzenmike Posted August 5, 2021 Report Share Posted August 5, 2021 4 hours ago, thisismatt said: Hillary doing an impersonation of one of Bill's White House interns. 1 1 Quote Link to comment
d.p Posted August 6, 2021 Report Share Posted August 6, 2021 18 hours ago, Charlie69 said: I have been here much longer than either d.p so I really do not think I will be going any where. d.p try contributing instead of whining. By the way when you d.p have over 40 plus years experience in 320s, 520s, & 521s then talk to me. I guess we have another Ratsun member with sand in his vagina! LOL Time =! expertise my man. You have been doing this for over 40 years yet you are today, in the lords year 2021, recommending people switch from a manual to an automatic. So I really got no idea what you have been doing other than swapping manuals for autos over the past 40+ years. And come to think about it I have gotten more knowledgeable insight and direction from mainer and crash then I have from you and those guys have been here as long as me or less. I have no sand in my vagina, let alone have a vagina. I am just here telling it like it is. Quote Link to comment
Charlie69 Posted August 6, 2021 Report Share Posted August 6, 2021 d.p opinions are like assholes!!! LOL 1 Quote Link to comment
